Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
Viking freezer leaking
Defrost pan is empty Bottom of freezer section has 1/8" ice created. I completly broke out and cleaned, 1/8" ice created again and water is leaking to the floor. Ice Maker is full. Freezer is neither overloaded or does it seam to have any signs of blockage Door appears to be sealing correctly. Problem seams to be ice maker leaking to bottom of freezer and creating ice slab then intermittently leaking thru botViking 42" VISB423 Water leaking from bottom of freezer tom of door ???
  • 2 more comments
  • alejandro902 Feb 21, 2009
    AT the bottom of my GE fridge frezeer is ice created by drops of ice maker, how ever, every 10 days I may turn out and clean all ice formed...
    There is something wrong with it how could I repair, the GE technical had no response when he came one year ago.
  • Anonymous Mar 15, 2014
    Water leaks from the right hand side (looking at the unit) from what appears to be the freezer (not the side where the ice cube maker is). The freezer door is cocked slightly but it closes and it does freeze good. The unit is 3 years old or so.
    What could cause the leak?
  • Anonymous Mar 16, 2014
    condensation on bottom freezer seal viking
  • audiofn Apr 04, 2015
    I had this same problem with my Freezer for a long time. After a few visits from the tech with no progress I decided to go at it myself. What is happening is that the drain keeps freezing. IMO there is a design flaw with the drain. I think that they probably should run the defrost cycle longer or wait longer before they start to cool again. The water freezes up before it has time to run out the bottom of the drain. Once this happens eventually the drain freezes up entirely and won't melt when the defrost cycle happens. The melted water has only one place to go and that is out the front and onto your floor. I took out the rack and drawer. I melted all the ice that was causing the door to not close all the way. I then removed the back panel of the freezer to expose the coil and drain. It took some time but i melted all the ice back there as well including making sure the drain was 100% clear. Once I did that I wrapped 1 copper wire around the heating coil on the front of the heating coil and another around the back of the heating coil. I did this directly over the drain hole. I then twisted the front and back wire together so they would center over the drain hole. I extended the wires down into the drain hole and made sure it was just sticking out the bottom of the drain hole but not touching the drain pan. Now the idea is that when the heating coil heats up it will transfer enough heat down the wires to melt any ice in the drain. So far it has been a month and there is no ice even behind the cover (you can see through the holes in the bottom) and the drain is still clear. little early to claim 100% victory on this but in the past I would already see some ice build up by now. Hope this helps others as this was driving me crazy and the idea of having to replace a very expensive fridge over something like this was driving me crazy.
  • 72 Answers
You have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Posted on Jun 17, 2009
SOURCE:
HMG1947 with ice maker. Intermittent problem getting worse! I am getting water on the inside bottom, which will leak out onto the kitchen floor if I don't catch it with paper towels under the bottom...
Is the freezer section cooling properly. If yes, then problem is drain hole blocked in freezer section.There is a water drain hole, which runs to the drain line.But if the drain hole is got clogged by ice, then water will leak from other end and you get water in bottom drawer.-------- try manual defrost procedure.----------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check, do you notice the same problem, if yes then defrost assembly board is faulty.But in most cases defrost reset procedure helps.----------- Thanks.Helpmech.
Sep 16, 2011 | Admiral Refrigerators
Water leaks under viking professional and there is about a 1/4 inch build up of ice on floor of freezer(which is on the bottom) on the floor of the pull ot freezer
Your drain is plugged. Basically the freezer goes into defrost and melts frost off the condenser coils. A big piece most likely fell off and freezer came out of defrost before it coulld melt and drain out completely. To fix you have 2 options. Have towels
#1- move contents of fridge and freezer to a backup fridge. Leave unpluged with doors slightly opened for 24 to 48 hrs. Use towels to cleanup any water. Plug back in wait 2 hrs to make sure temp gets back down before putting contents back in fridge.
#2- Remove contents from fridge and put in ice chest. Have towels ready. Remove ice maker ( if there is one) usually two screws on top hard to see and one on bottom. Disconnect the quick connect for the ice maker. Remove screw on back wall. Be careful when removing air vent on back wall. Its plastic and can break. Remove back panel. Look on the silver plate under coils and you will see ice and where the drain is. Remove ice than pour hot hot water down drain until it flows freely into drain pan under fridge by compressor. It may look like there is not ice make sure othyerwise you will be doing this all over again in a few days. Once water flows freely put everything back together wait about 2 hrs for freezer temp to get cold enough and than you can put contents back in freezer. If you have any question or need help please feel free to comment me back.
Jun 05, 2011 | Viking Professional Series VCBB36 Bottom...
Water collects at the bottom surface inside my Viking Refrigerator every few days. I have checked the drain for the freezer auto defrost and it does not appear to be blocked.
Take a large syrenge filled with hot water and flush the defrost drain.If this is clear,unplug the frig and empty the freezer section. Remove the rear cover of the freezer with fan assembly. Observe if the drain trough under the evaporator (large alumanum grill) is frozen over with ice. If frozen, let defrost and clean.
Reassemble rear panel..
Dec 29, 2009 | Refrigerators
Refrigerator Freezer has ice forming in the bottom inside freezer section. It appears to be leaking down the back inside compartment. The top section has an ice maker and water dispenser but I haven't had...
I believe you just described a defrost condensate blockage that is causing the leaking. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a in the defrost pan, water leaking and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
Nov 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
General Elec. refrig. about 12 yrs. old. water in bottom of frig., cleaned up, found water a second time.
drain is cloged. at some point the ref section was set too cold. the defrost water from freezer drains through the ref back wall. becaust it was set too cold the drain froze. two ways to fix .... empty unit and unplug for 24 hrs. OR remove back panel, defrost drainrail, remove bottom panel ,remove ice, insert 1/4 inch tube down drain, and squirt very hot water down drain till it is clear of ice..... when defrosted set ref on "3"
Aug 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frost Developing in Freezer. Refrigerator not
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Water pan inder freezer is full & leaking water
it may be that your defrost drain hole is blocked at the back. check it out but runnin a flexi band down it. if its the freezer drain hole you will need to do a full defrost to unblock ice.
Mar 16, 2009 | Refrigerators
Just found a huge leak
water in pan should evaporate of its own accord. you may have two faults. first, check door seals to see they mate with cabinet. if seals don't seal properly, excessive air will get in and hence the excess of ice. second, you should not have ice build up. remove back panel of freezer and check if evaporator has excessive ice build-up. if so, this points to a fault in the defrost system
Jul 20, 2007 | Viking DFSB483 Side by Side Refrigerator
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
5,549 people viewed this question
Top Viking Refrigerators Experts
Jay Finke
Jay Finke
Audie Bogus
Audie Bogus
Ekse
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
