Question about Brother LS-2125 Mechanical Sewing Machine
I have a White 3300 embroidery machine not catching bobbin thread
It has always worked properly. Just started yesterday missing up. The thread on the underside would bunch up. I lifted the plate off to remove the jammed thread. Now the top thread is not cathcing the bobbin. Any suggestions/
    Problem Solver:
  • 12 Answers
Try putting a new sewing machine needle in and make sure the eye of the needle is facing the right way. Needles look like they should go just anyway, but if they aren't in right, it could cause the problem you are having.
Posted on Jan 09, 2009
My elna experience 660 is bunching threads in big loops on the back of the fabric and the needle bent and hit the needle plate. It's sounding clunky
Install a brand new needle.
Remove the top thread from the machine (ALWAYS cut the thread at the spool, raise the presser foot, and pull the thread down through the needle eye.)
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
If it still does not sew properly or sounds clunky, take it for service. It could have been knocked out of time or bent something.
Jul 01, 2017 | Elna Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
The bobbin thread is bunching
if by bunching you mean thread looping on underside, then there is insufficient needle tension for thread control lever to set the stitch. check tensioner is working properly
Feb 23, 2014 | Brother Sewing Machines
How to adjust bobbin when using embroidery machine, bobbin thread bunches up
Check your bobbin case if it looks like it has and feels like there are barbs on it they catch the thread time for a new bobbin case. I had mine less than 2 months and had to get one my machine sews and embroiders great now
Nov 25, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
Fixing my white 3300 embroidery machine
First change that needle, it's probably bent. Then double check the bobbin/shuttle area for threads wrapped around moving parts.
Oct 24, 2012 | White Sewing W3300 Computerized Sewing...
Thread on the bottom side of stitch is all bunched up
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Oct 09, 2012 | Sewing Machines
I have a ce 100 and the bobbin thread comes up and gets into my embroidery pattern. how do i loosen the top tension to stop this from happening. my purple flower has white in it from the bobbin :(
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
Ce 5000 prw - upper thread bunching up on underside (lower thread ok), all stitches coming out strait or partial pattern then strait
try changing the needle
also check the top thread tension
check for lint under needle plate
some needles & thread aren't compatable--try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 12, 2010 | Brother Sewing Machines
Right after I start the needle sewing the thread bunches up on the underside of the fabric. I have tried holding the thread ends when I start sewing but it still happens
also check to make sure there is no lint or loose threads in the bobbin area
make sure there is no lint under the needle plate
some times the needle & thread are not compatable- try this & see if it work for you
Oct 11, 2010 | Singer 1120 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
241 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
