Question about Singer 7462 Mechanical Sewing Machine
Problem making button holes
I was able to make button holes easily on scrap material, but when I went to make it on the coat with iron on interfacing, I had problem with the button hole going off track or stopping and make a huge knot on the bottom of the button hole and not completing the button hole. Does anyone know how to fix this. It was almost like the feed dogs were down and not feeding the fabric through.
  • Anonymous May 04, 2009
    I have the same problem. Made a buttonhole for the first time on a scrap, it worked fine. Sat down to make another one on a scrap and it was as if the feed dogs were not moving (though they were). The fabric did not move, and it just kept stitching in the same place, making a ball of thread underneath.
  • 57 Answers
Try adjusting the tension a bit. Make a not of where it was origonally set.
Posted on Jan 05, 2009
Ellure Plus buttonhole disaster. The attachment doesn't work properly with thick materials. I used a medium to heavy weight wool (it was also faced with this material) and just a disaster! Help!
Unfortunately, you are stuck with having to fix what you have. Perhaps handstitching the buttonholes with heavy thread will at least make it acceptable. In the future, be sure to always test the exact same set up using scrap material before trying it on your project.
Dec 20, 2017 | Sewing Machines
What #holes on 158.1786181 solid state Kenmore sew machine bobbin
Do you mean the lower bobbin spool? It should not matter too much so long as it fits. Try it on a scrap of material and see how it goes.
Mar 02, 2015 | Kenmore Sewing Machines
How do I make buttonholes on the Bernina 180?
I don't know about your Bernina but mine you have to manually set the button hole size every time you do a new button hole size. Practice on a scrap bit of fabric. I think you push the buttonhole button - sew which I think does an end, push the button again, sew for the distance forward you need and push the button again, and sew the other end and push the button again and it should go back to the beginning. That's off the top of my head, I could be wrong but try it on scrap. I think it might then have set the size until you change stitch types and it should continue to do the same amount of forward and back stitches with each button press to tell it to go forward, end, back, end etc. But practice! My machine has trouble feeding the fabric evenly.
Sep 13, 2014 | Sewing Machines
How do i widen buttonhole stitches to make larger buttonholes?
Stop using the button hole program ! Use the button hole foot but do the stitch by hand adjusted satin stich ! Remember to lock off after each rib sewn !
Aug 27, 2014 | Sewing Machines
When i start sewing sometimes the material gets sucked down into the feeds dogs. this causes the thread and the material to make a mess i sometimes can not get the thread out i am making quilt pieces
Use a scrap of fabric under the pressure foot as a leader and feed the quilt square after it clears just like if you are chain sewing. After you have sewn the square clip the scrap off and use it again.
Feb 09, 2013 | Brother LS-1217 Mechanical Sewing Machine
My zig zag stitch is puckering fabric. I even went to the multiple zig zag, same problem. I decreased tension. What should I have double. Note: this was on single layer, along edge of fabric so I could...
Check the bobbin tension too. It could be too tight. Make sure you are using the right size needle for the material as well. Sheer, thin fabric needs a smaller needle, thicker material requires bigger needles. Bobbin tension is the typical problem as most think to adjust the top tension but don't check the bobbin tension.
Is your quilt peices cotton? Cotton shouldn't cause as much trouble sewing along the edge but don't use too long of a stitch length else it will seem to gather up. Puckering side to side however is a tension problem usually. With sheerer fabrics that cause a problem sometimes you can put thin paper underneath, sew through both and then pull the paper off after sewing. (thin like the iron on type interfacing type fabric but like paper).
Mar 25, 2011 | Janome Sewing Machines
Hello. I have a Singer Model 1411. I was going along, switched over to the zigzag stitch, and when I came back to the regular stitch, the machine thinks it's making a buttonhole instead.of a straight...
Well, I think you confused your machine. Go back to the zig zag and sew on a scrap piece of material. Stop sewing and carefully go back to regular stitching. Make sure your stitch length is correct and you have everything tightened up and the feed dog is raised. If this doesn't help, try doing a button hole stitch for a bit, stop sewing, go to zig zag, stitch a bit and go to the regular stitch and see if that works. If not, you may have to take it in to be reset. Good luck.
Nov 28, 2017 | Singer Sewing Machines
I have a Kenmore 19606, I have never own a machine that does embroidery stitches, the pattern of the stitches shows on the wrong side of the fabric not the right side. Is this suppose to happen? If not how...
Not sure if you are doing embroidery w /a hoop and all, which I don't do but I have lots of decorative stiches . Ytp lacing some tear away interfacing below the fabric you are going to sew. Most stitches come out top to bottom. Say I have an alligator option. Image will be about 1 1/2 inch , Try it on a piece of scrap fabric to start. I used muslin and the tear away bnacking to stabilize the design on lettering and patters.Also use good thread. I like Guttermans. Coat and Clark / Sulky are very fine and snag and tear easily. Good luck. Keep trying. The design you sew will show on both sides , so if you do not want that you will have to add another level of fabric to the backside after completing the design. Hope that makes sense.
Mar 29, 2009 | Kenmore 19606 Computerized Sewing Machine
Automatic Button Hole
perhaps look up the user manual online, or get in touch with your local dealer.
Apr 08, 2008 | Janome Memory Craft 4800QD
The button hole option isn't working.
You can use the regular plate and you are correct in that it should make the button hole automatically. If the material does not move, the pessure on the pressure foot is not enough.
You can try the following:
First make sure you select a button hole patern.
You can also place a piece of stitch and tear paper underneath the material to help with the movement. If you dont have any, try normal tissue paper.
Hope this help you
Dec 08, 2007 | Singer 7422
Singer 7462 Mechanical Sewing Machine Logo
165 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
