Monitors
Problem for Monitors
Generic problem for all Monitors
Error message on new monitor
By katattexas on Jan 01, 2009
I have a new LG Flatron monitor, and when I turn it on I receive an error message "ANALOG OUT OF RANGE" What do I need to do???
Comments:
Jan 03, 2009
- Hello,, thanks so much for the info,, but I worked it out,, I actually needed to install the driver since I was running XP, and it was not set up for the digital monitor.. But I really appreciate your reply.. have a great day..
Solution #1
posted on Jan 02, 2009
Somewhat Helpful)
yourhalf01
Rank: Guide
Rating: 72%, 2 votes
I don't know for sure because I don't own nor have I ever used one of these monitors before but this error likely means that either that there is a problem with the resolution or the frequency coming from the video card on your computer. The recommended resolution is 1280x1024@60Hz.
You can hook your PC up to your old monitor and check the Display Settings. According to the manual for the LG1780U (and many others) 640x480, 800x600, 1024x768 and 1280x1024 should all be acceptable values, although 1280X1024 will give you she sharpest image for this monitor.
If you still need help LG offers 24/7 tech support @ 1-800-243-0000.
I hope this helps!
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
Samsung 204BW Replaced blown caps on the inverter board and burned in for a day and 1/2 then the... (More)
Answer
i am using a syncmaster 753s model monitor now the letters on the screen are not clear (focus out)... (More)
Answer
how do i set horizontal position ? i push ''1'' then ''>'' (to get to H. POSITION) then ?
Answer
I'm having trouble with streaking on my HP W2007 Monitor. Any suggestions on how to correct this?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Monitors:
Top Monitor Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
