Question about Dishwashers
Dishes still dirty, or gritty after wash cycle completes.
It appears especially on glassware that there is a residue on the dishes after the complete wash cycle. Is there something that needs to be cleaned to prevent the problem and get the dishes cleaner? The machine is a Maytag Quiet 300 Series. Thank you.
    President:
  • 2,110 Answers
If you have suds that may be the problem.
The motor sucks in water/suds due to the air bubbles it cavitates.
Once suds get into a unit it will take several cycles to clear them.
Run a cycle, do not add soap, once filled add a cup of vinegar, let it do the wash, after the rinse fill put in another cup of vinegar let it finish the cycle.
Do another wash cycle, without soap. Let it start washing, open the door, are the suds gone.
Note some people use a tablespoon of vegetable oil to kill the suds. Have never tried this.
Does the pump sound better?
If yes you have to figure out what is causing the suds.
Have you changed your soap or rinse aid lately. Do you do dishes by hand once in a while? Could be they are not getting rinsed well enough. It takes very little dish wash soap to cause suds.
Also a low fill level is a possibility. Let it fill add a quart or 2 of hot water.
Does the pump sound OK?
Most units fill to just under the heating element. Not sure about this one.
If adding water fixes it problem is probably a dirty filter screen on the inlet side of the water valve. remove the valve and clean the screen. Do not remove it, it is there to keep crud out of the valve which could hold it open and cause a flood. Also a good idea to drain some water out of your hot water tank. Use the drain or the pressure relief, let it run till the water is clear.
Posted on Jan 01, 2009
    Genius:
  • 3,422 Answers
HI,
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
My dishwasher is left quite wet inside after washing dishes. Is this unusual, especially for an expensive Viking dishwasher that is brand new?
make sure you have selected the heated dry option. for the smell, add a 1/2 cup of white vinegar to wash cycle.
Jun 21, 2015 | Viking Dishwashers
LG dishwasher
If you're sure you're using enough soap, check that your hot water is connected and that you're using a hot-water wash (some dishwashers have a cold-water option, this will often give unsatisfactory results if washing greasy dishes - especially beef fat).
Jul 02, 2014 | Computers & Internet
The dishes have a gritty residue on them after the wash cycle is complete.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Jul 02, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Gritty/sandy feeling on dishes from dishwasher
You could only check the basics. Since the dishes are clean, it means they went through the wash cycle. It also means that that the holes on the washer arm are not blocked. If they were salty and dirty the wash arms would be something to check. And since they came out feeling like salt is on them its possible they didn't rinse and its also possible the dirty water didn't drain.Were your drain and fill hoses checked or did the techs just check the dish washing machine itself? Its also possible the water for rinse is not hot enough. Before the rinse cycle comes around try running the hot water at your kitchen faucet. Any other issues may be within the cycling of the machine.
Apr 29, 2010 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwasher leaves behind gritty residue i am not sure of what to try...
We have a Kitchen Aid dishwasher, 10 years old, never any problems until 2 weeks ago, then we started noticing a gritty subtance on the dishes and glassware. We're on well service, psi 40-60. water hardness is 6 grains. small trace of sulphur, and we have a Mermaid sulphur system, then a complete house carbon filter, and finally a Culligan water softner. Checked everything, Water temp. at kitchen was 120, all cycles on dishwasher were operating. Called in repair service, he says something is breaking down in the dishwasher, best to buy a new one. That'll be $150.00. Thank you very much. Tried the white vinegar, no change. Next bought 2 bottles of Dishwaser Magic. Slight improvement. Next bought 1 bottle of Finish Dishwasher Cleaner. Bingo. The thing is like brand new. even the trays slide in/out much easier. None of the dishsoaps contain phosphate, which is what helps disolve the minerals in the water. I'm not sure what the gritty stuff is, maybe the buildup over time, and it just keeps getting redistributed through the wash and rinse cycles, and finally baked on in the dry cycle. According to a tech with many years repairing appliances, the majority of their calls are for dishwasher poor performance, all because they removed the one compound that's been cleaning our dishes for years, Phosphate. We've always used Cascade gel soap. best on the market today, Finish Quantum. We tried it and dishes look terrific. It's a small tablet that fits in the soap dispenser. All Mfg's. today recommend that you run a dishwasher cleaner once a year, Experienced tech recommends every 3 months maybe more if you're on hard water. Good luck.
Mar 25, 2010 | Maytag Dishwashers
After cycle is complete a residue stays behind on glassware and inside appliance
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101 .,,.
Mar 13, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
My electrolux icon dishwasher leaves food residue in the interior of glassware and mugs. It has etched and left milky scratching permanent texture to all glassware. I have replaced glassware change...
heatman101
Mar 10, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Glassware is cloudy
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Nov 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes recently started feeling gritty after cycle is complete. I cleaned the dishwasher, ran a full cycle w/o dishes, and added JetDry, which has helped some, but problem persists. The unit occasionally...
It is possible your dishwasher is dirty. I have found this wonderful product called "Dishwasher Magic" It cleans rust, midew and scaling from deep inside your washer leaving it like new. Try it it's a wonderful product
Nov 18, 2009 | Refrigerators
Washing leaves spots
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you're using and adjusting your hot water heater's water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water. First you'll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, you can wash the glass with warm water and concentrated dishwasher detergent or use a high-phosphate detergent (such as Glass Magic) according to label directions. If film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature. See "Doesn't wash well," above. Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn't anything you can do to make it clear again. But you can avoid future etching by taking these steps: 1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don't use extra hot settings, such as "Power Scrub" and use "Energy Saver" dry cycle. 2) Adjust detergent amount. 3) Don't pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Dishwashers Logo
52 people viewed this question
Top Dishwashers Experts
