Electrolux washing machine EW1055F stopped working
The pilot lamp doen't come on and the washing m/c doesnt start. Can't find a fuse anywhere on the control board. Any suggestions as to what could go wrong?
  • 15,935 Answers
It appears your controller/timer board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Electrolux EWF1074 suddenly no power at all. Working fine before.
While there could be many reason, begin by looking at the power source. Has it tripped a circuit breaker or blown a fuse?
The most common cause:
If the fuse is ok next check the door interlock. If the lights come on but the machine won't start, this might be the issue. The door interlock is the safety device that sends a signal when the door is securely closed so that your washer can run. You will need to call in a professional to trepair this fault.
Less possible but still reasonable:
If you've run several loads, one after another, your washing machine may refuse to start due overheating.
You will find a more detailed explanation here
My Washing Machine Won Start Find Out Why
Jan 11, 2018 | Electrolux Washing Machines
Front loader washing machine EWF1087 stopped half way and did not drain, E50 was displayed. Emergency emptying out the water was done and try to restart. Could not start, still displaying E50. What to do?
the error code E50 indicates that the motor has become overheated, you should give it an hour to cool then try running the washing machine again. I'm also including a link to pdf below with the common error codes for your brand of washer in case you have any other problems
http://www.applianceblog.com/mainforums/attachments/frigidaire-electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwashers.pdf
Jun 17, 2011 | Electrolux Washing Machines
My washing machine door doesnt lock properly
its most likely your door lock if it is malfunctioning the washer will not work
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
Washing machine wont work at all
Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Mar 19, 2010 | Washing Machines
Electrolux oven eog7330xn stopped working
Hi Chaps,
I have an 18 month old Electrolux Gas oven model No: EOG7330XN which worked for 14 days then died. There was no power displaying and I called Electrolux to service within the warranty period. The engineer removed the front control panel and replaced a fuse inside which brought it back to life.
Am I right this is possible, I have removed the panel but can't see any fuses?
Jul 30, 2009 | Electrolux Ovens
My front loading electrolux washing machine is stopping after a few cycles .I want know address of authrised service provider
If you live in the U/K, then look for Service force in the telephone directory, they are are the agents for Electtrolux
Please rate my solution.thanks.
Jul 15, 2009 | Electrolux Washing Machines
I need to download a users manual for a Electrolux EW1055F washing machine for free
Hello michael360,
Copy and paste this link http://safemanuals.com/user-guide-instructions-owner-manual/ELECTROLUX/EW1055F-_E. Towards the right side of the page you will see a pdf icon to download the manual. Hope this helps.
Thanks,
edgin96
May 02, 2009 | Washing Machines
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
