Question about Tappan Microwave Ovens
User manual for a Tappan mod TMV151FS
Tappan installed in apartment, no instruction books available, need info on how to use.
  • Tappan Master
  • 9,086 Answers
You can download your owner's manual here.
Posted on Jan 01, 2009
Where is the fuse on a tappan
Posted on Oct 10, 2012
Tappan Electrolux tmv151fs microwave/rangehood. turntable and cavity light intermittent (but work/fail in unison), all else work ok
Either a wiring problem or worn contacts on the relay that powers the two would be possibilities.
Nov 24, 2016 | Microwave Ovens
Where can I get an instruction manual for a Tappan mod. 56-4804-10-08 microwave oven? Thanks
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download if available, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
I hope this helps.
Jan 23, 2011 | Tappan Microwave Ovens
My Tappan TMV151FS MIROWAVE OVEN DOES NOT WORK THE MESSAGE READS (SE) IN THE LCD WINDOW CAN'T LOCATE MY OWNERS MANUAL CAN YOU GIVE ME ANY INFORMATION ON THIS PROBLEM THANK YOU LEO LAFLER
"SE" means you have a shorted membrane keypad.
The most economical repair (and a pretty simple one) is to replace your entire controller assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Model TMV151FBA is black and model TMV151FSA is white.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
You would order one of these here:
PART DESCRIPTION COST
5304456080 Control Box, assembly, black $145.14
5304456081 Control Box, assembly, white $149.42
Sep 07, 2010 | Tappan Microwave Ovens
I need an Instruction book. The unit came without one.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can download GE owner's manuals and installation instructions here.
Sharp here. Panasonic here.
If I didn't correctly guess your mystery brand, please post a new help request including your brand and country.
Aug 20, 2010 | Microwave Ovens
Where can i get a user manual from
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Filter replacement
That's covered on page 20 & 21 of your owner's manual under the heading"CHARCOAL FILTER REPLACEMENT"
1. Unplug oven or turn off power at the main power
supply.
2. Open the door.
3. Remove the two vent grille mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
You can find helpful exploded view diagrams and order parts (including filters) by entering your full model number from the tag on the oven here.
Feb 16, 2009 | Tappan TMT104E1 Microwave Oven
Total power loss during use
Check the voltage on the outlet,make sure it is 115v -- 122volts max, any less will cause it shut off, make sure the polarity off the outlet is correct and it is grounded,check all of your wiring connections, if all this is ok replace unit with a different unit or different supplier of unit
Jan 26, 2009 | Microwave Ovens
Microwave Ovens Logo
1,960 people viewed this question
Top Tappan Microwave Ovens Experts
William Miller
William Miller
Mark Gough
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
