Question about Apple iPod MA446LL/A MP3 Player
IPOD will not Play and no control over center options
My IPod will not play. It is stuch on pause and I can'y get it to play again. I have tried lock and ub-lock which wirkd great. I can increase the bar line for volume but it will not move off pause. The battery is showing fully charge. Ihave the 160GB model.
I can't do anything with the center options except adjust volume. Bo Menu /next play or nothing.
Display and lock switch worke great
  • chasbutler23 Jan 02, 2009
    My IPod will not play. It is stuck on pause and I can't get it to play again. I have tried lock and ub-lock which works great. I can increase the bar line for volume but it will not move off pause. The battery is showing fully charge. I have the 160GB model.
    Display and lock switch works great.
    Hope this help clear up what my kid wrote.
    President:
  • Apple Master
  • 688 Answers
There are a few things that may cause this problem.
1) the click wheel could be bad. Find a Replacement
2) the motherboard could be bad
3) the click wheel center could have pushed in and turned causind it to stick. Make sure the center button moves freely and you can feel a click when it's pushed. if not you can open the ipod and realign the center button.
Posted on Mar 02, 2009
30gb ipod freeze up cant shutdown to reboot
Slide the Hold button on the top of the iPod so no red mark is visible. Press the main menu button until you see a long list of options (Artists Albums Songs Extras......) use the scroll wheel to find the sleep press and hold the center button in or Locate the Play/Pause button on the iPod. The Play/Pause button is at the bottom of the wheel around the select button. Press and hold the Play/Pause button until the unit powers off, about three to five seconds. Press any button on the iPod to turn the power on.
Feb 14, 2013 | Apple iPod Audio Players & Recorders
Trying to swicth off my i pod
Feb 03, 2013 | Apple iPod MA446LL/A MP3 Player
How do I turn ipod off
iPods have no traditional on/ff switch. They power up with the slightest touch, which makes turning the iPod on as simple as touching the menu. Turning the iPod off, however, can be more tricky. Waiting for automatic shut off wastes battery life, and surfing the menus yields no way to stop the device from running. Turning off the iPod Nano, though, is almost as simple as turning it on.
Locate the "hold" or "lock" switch at the top of your iPod Nano. It will be located on the top of your device on the left side. Make sure the device is unlocked. When the device is locked, an orange bar is visible. When it is unlocked, that bar is not visible. The iPod needs to be unlocked in order to power off. Locate the "play/pause" buttons. These are located at the bottom of the control wheel. Press at the "play/pause" section of the wheel and hold for a few seconds. Your iPod will power off. Do not touch the wheel again after powering off, as this will power the device back on. Locate the "hold" or "lock" switch again. Slide the bar to the locked position so that the orange bar is visible. This will prevent your iPod from powering on in your purse or pocket and wasting battery time.
Jan 26, 2013 | Apple iPod nano
Froozen and wont do ANYTHING
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    • utting iPods with a Click Wheel into disk mode
      1. Before placing the iPod into disk mode, you should verify that it is charged.
      2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
      3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
      4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
      5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
      If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
      If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Jun 05, 2010 | Apple iPod nano
When i got done chrging my ipod it froze
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
Resolution If you experience any of the above issues, try the following steps:
Dec 17, 2009 | Apple iPod Photo MP3 Player
80 gb ipod, I will go to any song and hit play. It will not play.
My ipod will not play after I paused it. It was playing fine before I paused. It was recharged completely before that.
Jul 07, 2009 | Apple iPod MA446LL/A MP3 Player
I Have a 3rd gen ipod and its stuck on the lanuage
Try reseting it. If that does not resolve the issue, put it into disc mode and restore again. If these steps do not help please let me know.
Learning how to reset or restart your iPod:
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Putting iPods with a Click Wheel into disk mode Before placing the iPod into disk mode, you should verify that it is charged. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
May 05, 2009 | Apple iPod nano 3rd Generation
My ipod isn't recharging or even turning on.
try putting the ipod into disc mode before connecting it to your computer to restore. Just in case you are unsure on how to put an ipod into disc mode, I have posted step by step instructions below. This is the only other option to restore the ipod and not need it repaired or replaced.
I hope it works for you :)
Apr 25, 2009 | Apple iPod nano 3rd Generation
My ipod chromatic is completly frozen.
You are doing the reset wrong. Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Apr 07, 2009 | Apple iPod nano MP3 Player
Third gen...
Try holding the PLAY/PAUSE and center buttons down for 10 seconds. This is a reset for the iPod.
Make sure the HOLD switch is not turned on. This locks out all controls on the iPods.
Apr 11, 2008 | Apple iPod nano 3rd Generation
Apple iPod MA446LL/A MP3 Player Logo
42 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
