Question about Maytag Performa PAV2200
No heated drying
I get no heat while the clothes are drying.
  • 1 more comment
  • Anonymous Jan 01, 2009
    I have the same problem. Electric
  • 1titansfanmo Jan 03, 2009
    The dryer gets hot for 15 seconds then doesnt get hot anymore.what causes this?
  • Robert Siegel May 11, 2010
    is this a gas or electrical dryer
    Genius:
  • 2,920 Answers
It could be either the heating element or limit switches keeping it from heating
Posted on Jan 01, 2009
Whirlpool Duet Steam is heating up to dry any clothes
Sounds like the heating matrix/element has failed, or some other internal component has failed. If you can return it under warranty, do so. Otherwise you'll have to pay an appliance repair engineer to repair it for you.
Jan 21, 2014 | Washing Machines
What is the heat selector knob?
This allows you to adjust the temperature to match what you are drying. Some fabrics and clothes require low heat or you may only be drying a small amount of clothes and don't need much heat. You also may not want high heat to avoid shrinkage of some clothes.
Jul 16, 2012 | Avanti D110 Electric Portable Dryer
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Dryer heats up but doesn't dry clothes take 3 hours after restarting 3 times to dry 3 articles of clothing.
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
Oct 15, 2009 | Whirlpool LER4634J Electric Dryer
My GE dryer is tumbling & heating but not drying.
there may be heat but if your heating element is not working properly it will heat some but will not dry cloths
Nov 15, 2008 | GE DBL333EA Electric Dryer
Our LG dryer doesn't get completely hot until the clothes are mostly dry.
heated air enters the dryer at 140 degrees farenheit,
a portion of the heat energy raises the temperature of the water in the clothes.
When the clothes are cold and wet, the difference is large transfer is rapid
a lot of heat transfers to clothes and the exhaust air is damper and colder
As the clothes get warmer and dryer, proprtionally less heat is extracted from the incoming air, and the exhaust air is warmer and dryer.
When the clothes are dry, and at 140 degrees, the same temperature as the incoming air. no heat is removed from the incoming air
the dryer should then stop heating, draw unheated air through the drum and clothes to cool, and reduce wrinkling
then switch off
the dryer appears to be operating correctly
Oct 31, 2008 | Dryers
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Does not heat up when drying clothes
heating element is most likely shot.
good luck
please mark the post with a fixya
Feb 19, 2008 | Hoover Nextra HNWL 3126 Front Load Washer...
Washing Machines Logo
29 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
