Question about Panasonic Televison & Video
I have a 3 1/2 year old Panasonic TH-42PX50U TV that has recently been spontaneously clicking off usually both the video and audio. The red LED above the on/off switch will begin flickering at the same time. The remote & TV on/off switch at the same time will not operate. Eventually in 10-20 minutes the light stops flickering and both the switch and remote again function--and the TV works normally. These events definitely occur more frequently the longer we try and use the TV. If the set is unplugged for a few seconds, however, it is operational sooner. The same problem occurs if the TV is plugged directly into the wall or into a surge ;protector. Is there an economical fix for this problem--is it over-heating an electrical component-do I need a new TV? Lou
  • lrfeld Jan 01, 2009
    Is this a known problem with this TV and would is it usually worthwhile pursuing a full service call? I know enough without your consultation that a tech can perform an in house circuit check, but wanted to know if this is a known fixable problem that would make economical sense..
    The sol'n was adequate, but still did not answer the question if this is a frequent problem particularly with this TV or plasmaTV's in general.
    Genius:
  • 2,920 Answers
It can also be a bad flyback....they are notorious for going bad
Posted on Jan 01, 2009
    Genius:
  • 1,011 Answers
Sir,
The problem could occur if attached to a surge protector. Also open the tv and check the power supply board it may lose solder joints or connections. Check external output souces it correctly plug in or not?
thanks
good luck
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, I doubt if there are any major components defective. From all indications based on your description, possibilities are:
  • heat related issue;
  • cold solder joints;
  • leaky capacitor particularly in the power supply board, especially the +5VDC rail and the mains B+.
The repair would be low cost if you are considering a DIY (do-it-yourself) repair. However, to be able to do this, you must have some familiarity with electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY, perhaps your best bet would then be to seek the services of a qualified professional. If the cost of repairs and downtime would be factored in, then you may have to re-evaluate your options and consider a replacement.
Good luck and Thank you for using FixYa. Happy New Year.
    Genius:
  • 1,199 Answers
This sounds very much like your flyback on the main board needs replaced (this controls power flow and is overheating causing your tv to shut off and on! this part should only cost around $70.00
    Novelist:
  • 163 Answers
Might be a condenser is gone or going to dam, so they produce overheat. not a costly Fix.
  • ronny2051 Jan 01, 2009
    Thanks.
    no its not a general problem, Occurs because of many regions…
    1) high electricity
    2) due to some shorting on the main board
    3) or due to humidity climate(it effects the circuitry of any electrical devices).
    Genius:
  • 1,550 Answers
Its due to overheating in your tv . You need to call service person to open your tv and check the circuits .
How do i program a device using this remote
From what I can tell the EUR7627Z60 was originally shipped with the following Panasonic products: TH-37PX50U, TH-37PX50U, TH-42PD50, TH-42PD50U, TH-42PX50, TH-42PX50U, TH-42PX50UA, TH50PX50, TH50PX50U, TH-42PD50, TH-42PD50U
Here is the manual for the Panasonic: TH-37PX50U/TH-42PX50U/TH-50PX50U:
Panasonic TH 37PX50U Operating Instructions Manual
Best of luck!
Feb 03, 2016 | Panasonic EUR7627Z60 Remote Control
Tip
How to connect laptop to TV Panasonic TH-42PX50U
Hi,<br />i have TV Panasonic TH-42PX50U, but i don`t know how to connect it with laptop...<br /><span><span>Can I</span> <span>do it</span><span>?<br />because i bought cable and it doesn't works, when i connect they then on laptop is signal, but nothing happens on TV and laptop more... </span></span><span><span>I</span> <span>open the</span> <span>laptop</span> <span>program</span> <span>but</span> <span>there's</span> <span>no evidence to show... <br /><br />i hope somebody can help me!<br /></span></span>
on Dec 18, 2010 | Panasonic TCL42D2 42 in HDTVReady LCD TV
Led flashes 11 time
11 blinks to standby light of Panasonic Plasma TV indicates a fan error. If you wish to get more details about this fault, check this link.
Feb 05, 2013 | Panasonic TH-42PX50U 42 in. Plasma HDTV
My panasonic is not coming on,the power button is just flashing red(TH-42px50u)
Count how many times it blinks. Sometimes the problem is coded in the amount of times it blinks. If you see a distiction between blinks, say like 13 then a pause then back to 13 more blinks, google solutions for a 13 blink standby for your tv and you might be able to find the soultion.
Jun 14, 2010 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Does anyone have a panasonic TH-42PX50U Service Manual I could download?
www2.panasonic.com/consumer.../model.TH-42PX50U
www.nodevice.com/manual/.../panasonic/th.../get29233.html
www.panasonic.user-manuals.com/list-of-manuals-292-5104.html -
You can copy and paste any of these links into your address bar to bring you to your manual
Aug 25, 2009 | Televison & Video
1 yr old panasonic th-50pz700u shut off spontaneously and won't turn back on . red light blinks 8 yimes and repeats
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit).
This has to be replaced, call Panasonic and if you still have warranty you can get it replaced for free.
Jun 03, 2009 | Panasonic (TH-50PZ700U) Television
Panasonic TH 42PX50U Red power light flashes 6 times
Most of the time when this happens it is the ysus board, that noise you heard was a capacitor popping. Another board runs about $175 and thats if you do it your self. A shop will most likely charge around 500-600, hope this helps, you could also try contacting panasonic and trying to get past the tech and onto casemanagement where you might get somewhere with an out of warranty fix.
Feb 06, 2009 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Panasonic Viera TH-50PZ80U No sound no audio only buzz.
Found the screen had a small crack and was shorting the video circuit.
Jan 03, 2009 | Panasonic Viera TH-50PZ85U Plasma TV
Televison & Video Logo
16 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
