Question about Siemens WFXD8400UC Front Load Washer
Dropped drum i have a servis m3006 making terrible noise like something trapped between inner & outer drums. inner drum seems to have dropped, is it worth fixing its only two years old. many thanks
    President:
  • 1,462 Answers
Probable that the bearings have collapsed. remove back panel.undo wiring to heater and stats and make a note of where it goes. remove back plate of the tub assemby held by a clamp right round. drum andback plate then come out complete. take off pulley and put back bolt in shaft. tap bolt and you should be able to knock drum from backplate. you can then check bearings. you will need to replace bearings, lip seal and backplate seal.parts are not too expensive. check also condition of journal lip seal runs on. this must be in good condition.
Posted on May 07, 2007
SOURCE:
Zwf 1000m the drum will not move at all. i have checked the filter and it is is clear. the machine makes a small noise when the drum should start to move but nothing happens?
if you cant turn the drum by hand on the inside ,....there could be something trapped between the inner and outer drum........or worse.......the drum bearing mite be shot......ive fixed a few with womens knickers and bras jamming the drum as they ate flimsy enough the get between the inner drum and the door seal............good luck
Nov 02, 2013 | Washing Machines
Servis 1200 very noisy in spin modes. Inner drum seems to be very loose and wobbly. Noise sounds like a roller with flat spots running on the drum, or a very bad (failed) bearing. Machine is 12 years old,...
the bearings have gone, if the drum can be split, remove complete drum and replace bearings, if you dont think its something you can do, dont attempt it, but to be honest, its realitivly easy
Sep 09, 2013 | Washing Machines
When it spins, the washer makes a loud noise. it rattles. Also when it is doing the rinse cycle I can hear a vibration/rattling noise.
I'm sorry to say that tis is potentially very bad news. the problem you describe is almost certainly because the main bearing on the drum is worn out, allowing the inner drum to "flop about".
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. If the bearings are bad enough then symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is the result of the failing bearing allowing water to escape through the seal at the rear
Jul 07, 2011 | Maytag Washing Machines
Servis M6602W Washing Machine making scratching noise as drum spinning, I believe there is something gone through the holes in the drum and rubbing along the outside. How can I get access to...
There is no easy way to access the space between the inner and outer drum, unless you count cutting a hole in the inner drum and then welding it back up again afterwards. But it's hard to do this without leaving the drum unbalanced and prone to damaging subsequent wash loads. On some machines you can gain a very limited access by removing the drain tube running from the bottom of the drum to the pump. If so then you may be able to use long forceps to remove the item but may have to rotate the drum and tip the machine back and forward as you do so. Not easy when you're beneath the machine, so get strong-armed assistance.
What most often causes this problem is one or more bra underwires and they can be really difficult to fish out again, especially if they get chewed up and bent. Eventually the underwires often get chewed up and are then small enough to pass down to the trap just before the pump, so make sure that you regularly check the trap for debris as it may damage the pump or cause blockages if left unattended. If this has caused your problem then prevention is easy: never machine wash underwired bras.
Good luck, please take a moment to rate my reply.
Sep 17, 2010 | Washing Machines
Money stuck inside drum making noise
The easiest way to access the area between the inner and outer drums is to take the front off. Instead of something being in the drum making the noise it may be the front felt pads that the front of the drum turn on. It makes the same noise. They are replaceable.
Jun 19, 2010 | Washing Machines
Drum won't spin on its own, makes a low buzzing
either your bearings have gone or u have something trapped between inner and outer drum
Mar 20, 2010 | Washing Machines
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
Have a front loading washing machine, it is making a horrible noise when it turns
Either something has gotten between the inner and outer drums or the inner drum support bearing has gone bad. Almost complete tear-down to fix it. Lift up and down on the inner drum (when machine is off) to see if it seems somewhat loose and makes a clunking sound when you do so. If it does, that indicates a failed shaft bearing.
Aug 06, 2009 | Da-Lite Standard Fast-Fold® Projector...
CLUNKING NOISE - SOMETHING TRAPPED BETWEEN INNER & OUTER DRUMS?
Yes, there is something trapped between the inner and outer drum, you could try removing the sump hose from the bottom of the drum, this will give you more room to fish about than possibly removing the heater. If you do remove the heater, you may not get it back in, then you will have to fit a new one.
The sump hose is the large hose fastened to the bottom of the outer tub.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
Grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Oct 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Siemens WFXD8400UC Front Load Washer Logo
487 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Mike
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
