Question about Belkin (F5D7230-4) Router (587009)
Can not connect to msn now i have a belkin router
I've installed a belkin g+ mimo. but now both my computers can not connect to msn, i can get everything else but msn. one more problem, my msn is also my email address
    Problem Solver:
  • 6 Answers
You can still use your email address.. just go online to hotmail.com instead of messenger live..
with your router.. try unplugging it, and put it back in.. you have probably tried that already though xD
Do you use a wireless adapter.. looks like a memory stick?? if you do and it is belkin.. get another adapter.. i had a belkin adapter and it stopped working.. <<-- there was a fault with belkin.. so i bought another one.. and the problem went away..
Thats all i can tell you now... sorry
Posted on Sep 05, 2009
  • 336 Answers
What is the error message that you are getting when trying to sign in to MSN and what is your MSN version? Also, was MSN configured for dial-up internet access prior to the issue? It is possible that your msn browser is not configured to work with your new wireless connection. You may just need to set your connection settings in MSN to use your current internet connection. MSN Technical Support can give you the accurate steps in adjusting the MSN connection settings. you may reach them at www.support.msn.com
Posted on Jul 11, 2009
Colud yo please help me i have a belkin router installed but i on to change it to a different belkin router every time i tray to install new router ,message comes up can not find new router, do i have to...
1.Yes, you have to save the configuration of the old router to see where you have it .
(print this out so that you understand the configuration.)
2. Uninstall the software for the old Belkin router.
3. Connect the new Belkin to the computer
4.power the computer off / leave off for (2) minutes then turn on.
5. Run new installation software on the new Belkin router.
May 16, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to you secure a belkin G + MIMO router
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here
for step by step instructions
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I Cannot set up my wireless G plus MIMO router !
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 27, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g+ mimo router can't detect internet
have you tried resetting the network adaptor on the belkin, whictch provider are you using for internet connection?
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hi, i,ve purchased a belkin g+ mimo router, and now its up and running, but the only problem is that i cant connect to msn. it must be the router, because if i un plug it and use the old connection it...
Try to clear the cookies of your browser first. Also delete the browser history. If that did not help, try to reduce the MTU of the router. You can do it when you access the router's setup page through internet explorer http://192.168.2.1
Jan 01, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Setting up port forwarding: belkin wireless g plus mimo router
candice,
you can go to this links click here. Select the model of your belkin router and it will give you a guide on how to enalbe port for warding.
Aug 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
CANNOT CONNECTTO BELKIN G+ MIMO
Hello, Connect a crossover ethernet cable from the computer to one of the LAN ports (usually 4 grouped together) on back of router. Connect a crossover ethernet cable from DSL modem to the WAN port on the back of router. Enter The default address for a Belkin Wireless, 192 168.2.1 into browser address window. Hit enter, it will then ask for a password only. For default leave it blank and hit enter. You can change it later. This lets you into the settings. Look for WAN settings and make sure the "Dynamic IP" is selected. Save this and refresh the link. Bring up a browser and check for internet connection. There's a number of changes that can be made here. Let me know what happens.
Mar 13, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D7230-4) Router (587009) Logo
181 people viewed this question
Top Belkin Routers Experts
steve morris
steve morris
Christopher Thrash
Are you a Belkin Router Expert? Answer questions, earn points and help others
