Question about Linksys WRT160N Wireless Router
Trying to connect to my router from my wireless laptop but keeps saying secured network how do i get it to unsecured
  • Linksys Master
  • 4,338 Answers
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 01, 2009
I have secured my router by connecting my laptop to the router by ethernet cable so now my network comes up as security enabled but I can't seem to connect to my wireless network although it shows the...
Remove the neighbor's network from the preferred network list.
add your own network in the list. If your router is old router then upgrade the firmware of the router. Firmware is the software of the router.
You have connected your laptop to the router, to secure the wireless network. When you connect the laptop to the router, make sure that the wireless network connection will be disabled.
Once you change the wireless settings, enable the wireless connection and connect to your network.
Apr 25, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
My Router works only if I do not put security password on it.
The router works only if the network is unsecured.
When you secure the wireless network , make sure that you will change the wireless network name also. Because if you change the wireless security and if you keep the same network name then your computer will try to connect to the same network name with the old unsecured settings saved on the computer.
Try to change the SSID ( network name ) and security to WPA, check if that works.
If that doesn't work then I believe you will need to upgrade the FIRMWARE of the router.
Click here for more information about the routers and the wireless network
Jan 25, 2010 | Belkin Computers & Internet
Laptop stopped connecting via wifi to home network.
The wireless settings in the Belkin has been setup with encryption.
You can restore the Belkin back to the factory default by powering up the Belkin and press the RESET button for 7 secs.
It is not wise to leave your wireless router unsecured, anyone can access your network and Internet connection and use up your allocated download limit. Once you exceed your download limit you could be slug with addition charges - this depends upon your contract with your ISP.
For details on securing your wireless router and configuring the wireless card in the laptop, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 31, 2009 | Belkin (F5D7231-4) Wireless Router
I have a belkin wireless router and it has always connected unsecure. We have a new laptop and it won't connect; says has to have pin #.
To setup a secure wireless network and configure the laptop's wireless card to communicate with the wireless router, please follow my instructions on this link :-
Dec 16, 2009 | Belkin (F5D7231-4) Wireless Router
I have installed uninstalled my laptop to the netgear wireless. It won't connect to the secured wireless but only to tthe unsecured It then says TCP?IP disabled for this connection
Hi and welcome to FixYa,
Initially, which is the Netgear, the WiFI / AP router or the wireless networking card of the laptop?
Offhand, that there are at least two (2) networks that could be detected by the laptop indicates that the WiFi is both receiving and transmitting (it works and therefore the issue is settings & configurations). Which of the networks is yours; the secured or unsecured?
Alternately, determine the SSID of your WiFi network and the PASSKEY used or the security system used (if one is used in your system/network). Additionally, are you using the Netgear Smart Wizard Wireless Assistant or the Windows built-in Wireless Network Connection?
For the secured system, use the PASSKEY determined as per above; for the unsecured, it may be employing MAC filter, try manually inputting the IP Address, Subnet Mask and Default Gateway.
Postback result(s) / updates.
Good luck and thank you for asking FixYa.
Oct 14, 2009 | Computers & Internet
Unable to encrypt router
you have to check if you have the wep key enabled. when you put in the wep key, it should also be enabled so that your wireless network should say security-enabled wireless network. make sure to disconnect and connect again on your network after changing the settings to refresh your connection. hope this helps.
Jun 04, 2009 | Belkin (F5D5231-4) Router
Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Feb 11, 2009 | NetGear WGR614 Router
I have just got a Belkin N1 vision wireless modem router. I have set it up and have it working ok on a Unsecure wireless network. But as soon as I try to secure the network. I get the following message...
Right-click on the network icon in the bottom right hand corner of your screen, Press Connect to a Network. You should see your wireless network in the list. Before you secured it, you could automatically connect to it because it was unsecured. Now you will have to double click on it and enter the username and password you secured your router with.
Once you have done that, there should be a box for you to tick that says 'Automatically connect to this network'. Tick that.
Done.
Hope this helps
Chris (ziraffa)
Dec 20, 2008 | Belkin Computers & Internet
My linksys says it is unsecured. how do i make it secured?
I found a link on how you can secure your wireless network. Click here. Let me know if you will still have a problem.
Sep 16, 2008 | Linksys Wireless-G Broadband Router
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Linksys WRT160N Wireless Router  Logo
76 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
