Question about Insignia IS-LCDTV32 32 in. Television
My Insignia emblem light has stopped working also.....
The back lit screen was blue during channel changes it is now red and there are many red digital blotches all over the screen....mainly on something that is black.
  • 51 Answers
The LCD panel is most likely shot. Bring it into a repair depot to check. Hopefully, you're under warranty.
Posted on Jan 02, 2009
Where does the blue triggered wire on a pillow tft lcd 7 inch monitor go
if you mean the 7 inch pillow car/fpv screen from ebay/amazon, the blue wire is not needed if you just use the first video connection (AV1).
However, you can use it to trigger the AV2 channel by connecting it to +12V (the same as the red cable). as soon as you connect it, the screen switches to AV2, and displays the words "Car Back" in red in the top right corner. i think its supposed to be connected to your reverse light's positive connection, so as soon as you select reverse, and the bulb is lit, it will switch to AV2, and display the feed from your rear camera. (there may be a safer way to connect it to your car, but i can't see any reason why it would not work)
As soon as you disconnect the blue cable from +12V (or change out of reverse gear), the screen will go back to AV1, and the red text will disappear.
i suppose you could connect it to your power supply via a switch, and use it to switch between two camera feeds, but the red text is annoying, its probably easier to use the remote :P
Feb 26, 2013 | Computers & Internet
Ihave a insignia ns-lcd47hd-09 tv. when i press the power button the light turns blue but no picture comes on only black screen.
I think your insignia is set for SHOP mode instead of HOME mode. I changed mine to HOME and it's working fine now. Press your menu button and then scroll down to setup. You're looking for Plug and PLay which should be the very first choice. If it's greyed out as mine was you'll have to change your imput from HDMI to TV in order to get to the P&P. Once you're in the Plug and Play your first choice is language. The second should be SHOP or HOME. Make sure to select HOME. You can skip scanning for channels. This fixed my problem with the blue light. The store uses SHOP so if someone plays around and changes something, all they have to do is shut off the TV and turn it back on. Please let me know if this works.
Oct 03, 2011 | Insignia NS-LCD47HD-09 47 in. LCD TV
How do I unlock my Dacor cooktop
When your Dacor cooktop is locked, there will be a red light lit above the Dacor emblem located under your cooktop controls.
If you see this light, pressing the Dacor emblem for three seconds will turn it off and unlock your range. Pressing it again for three seconds will again lock your range and turn the light back on.
Another fun thing about that Dacor emblem is that if one or more of your elements are lit, tapping it twice in quick succession will turn off all elements.
Sep 04, 2011 | Dacor Millennia ETT304 Electric Cooktop
I need the insignia remote control code.
there are several and here they are 1181,1180,1175,1171,0103,0189,0217,0135,0133,0116,0167,1148,0456,0029,0905,1406,1407,1408
try each one seperate
press and hold the setup button until the red light stays on then if it is a universal remote press the desired mode button (example t.v.) the light should now blink and then stay on enter a 4digit code .
note:if the code is valid the light will turn off if the code is invalid then the light will flash.
now try it with your device on by pressing the channel up and down button.
note: if the remote does not control all the functions try another code.
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 29, 2009 | Insignia 42" LCD Flat-Panel HDTV
How do i program the control to the converter box!
Try these steps: 1. Turn on your TV and change it to channel 3 or 4. 2. Press the power button on your Insignia Remote control. The converter light will be turn on in stand by mode (the red light appears). Press the power button again, the blue light will be on. 3. On your Insignia remote control, press the menu button. 4. A menu items appear, navigate to the autoscan item to scan channel.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
Insignia tv, universal remote, and.....
Follows steps below to program your Insignia Converter Box:
1. Turn on your TV using your TV remote control and change its channel to 3 or 4.
2. Turn on the convert box; the blue light on the converter box is on. If you press the power button again, the red light on the converter box will be on, but do Not turn it to Red!!! Your insignia's other buttons will not response if it in red light mode!!!
3. Then press the Menu button on the Insignia remote control. A wizard will appear. The wizard does not appear if your TV is not in channel 3 or 4.
4. Follow the wizard instructions to scan channels.
Blue screen?!
im not sure what that button is for i think pan and scan but anyway try holding the power button down for several seconds to rebut the player hopfully this works let me know if not and well try something else
Sep 21, 2008 | Insignia Televison & Video
Insignia NS-32LCD will not turn on.
WIth the set only 7 months old, it should still be under warranty. The problem now is that by opening it up, you effectively have voided the warranty. That being said, the problem is that a problem has been detected internally and the set shuts down to prevent further damage. The first suspect is the main power supply board. I would try for warranty service first. If that is not available a local service shop should be able to take some measurements inside to detemine whether the power supply is not working correctly or if the suply is being told to shutdown. WIth what little info is available here and not being able to examine the actual unit, remote diagnosis will be difficult.
Keep us posted.
Dan
Aug 25, 2008 | Televison & Video
Insignia 42 inch TV won't turn on
The power supply is in the protect mode. There are many things in the set that can cuase this. Most likely there is a short on one of the circuit boards, or the power supply itself has failed.
You will have to have the set serviced in order to get it going again.
Jerry G.
Jun 03, 2008 | Televison & Video
Insignia IS-LCDTV32 32 in. Television Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
