Question about JVC PD-42WV74 42 in. Plasma EDTV
JVC PD-42WV74 tv turned itself off and unable to turn it back on. Green light blinks on receiver and TV.
I had the TV on yesterday for about the length of three different dvds. In the middle of the last one, the TV turned itself off and both green lights on the receiver on the TV were blinking. I was unable to turn it back on last night and couldn't do it this morning either. I just see the green lights blinking. Could it have anything to do with overheating? Does it usually take that long for it to return to "normal" and turn back on? I have never encountered that problem before. I had to assume that it had overheated but I was stumped after it did the same this morning.
  • 4 more comments
  • Clare Benavides May 07, 2007
    I forgot to mention that I currently have the TV set on the floor with both the receiver and DVD player side by side on the ground next to it. I recently moved so have been looking for a new stand for the TV. I didn't know if this could also affect the TV in any way.
  • Anonymous Jan 08, 2008
    HI
    I have same problem apart from the green light its not blinking but staying solid
  • jimmy311 Jan 08, 2008
    HI
    i have the same problem apart from the green light its satying solid
  • Anonymous Feb 07, 2008
    hi i have the same problem apart from the green light which is solid too
  • Anonymous Nov 07, 2008
    I have the same problem accept that know it has sounds and no picture. What can it be?
  • ambernikki42 Apr 12, 2009
    I have the same problem but sometimes the green light blinks when i try to turn it on and sometimes its solid.
Unplug the TV set, after a few minutes, plug it back again. If you are lucky, the TV will be okay!
Posted on Sep 07, 2007
For no known reason, we experienced the same issue. Our TV turns off on its own and the light starts blinking. I did unplug it for 5 seconds, but that really didn't resolve the issue. Perhaps unplugging it for a longer duration of time? Will try. Other then that, has any one else been successful at fixing this issue?
James
Posted on Feb 14, 2008
Ive just resoldered the main power supply board amd its fixed
Posted on Jan 04, 2008
Media receiver "on" button flashes 8 times and turns the Pioneer TV to standby.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 14, 2015 | Pioneer Televison & Video
JVC PD35D30 Plasma won't turn on anymore...
Yeah, I was going to suggest power supply issue. Plasmas IMHO, are not worth spending the money to fix. Its the reason why they are so cheap these days in comparison to LCD's. I had a 50" Samsung Plasma that went out on me within 2 years (E Buffer board and XMain problem). Its not about the manufacturer but more about the Plasma technology. Do a few searches about plasma and you will find a lot of problems with these tv's. Id say cut your losses, sell the TV for parts and buy a more reliable technology
Jun 07, 2010 | JVC PD-42WV74 42 in. Plasma EDTV
I have a Sony Wega KDF-50E2000 that doesn't turn on. The green light blinks for a minute or so and then the red "timed out" light blinks continuously. Yesterday, the TV turned itself off with the green...
Did you replaced lamp in TV recently?
I think TV needs new lamp as existing is either broken or dead.
Lamp replacement procedure would be mentioned in user manual or let me know to provide you more info.
Thanks.
Sep 16, 2009 | Sony KDF-50E2000 50" HDTV
I have the same problem with my JVC PD-42WV74.
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 27, 2009 | JVC PD-42WV74 42 in. Plasma EDTV
JVC PD-42WV74 Plasma will not power on ?
I believe that this monitor will not work unless you have the cable from the media center to the monitor hooked up, I have all the parts from one of these due to the screen being defective on one of my customer's TV like yours. I have the connection cable that I could sell for $ 20. + Priority shipping of $5.65
Oct 11, 2017 | JVC PD-42WV74 42 in. Plasma EDTV
JVC tv i'art blinking timer
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
Aug 23, 2008 | JVC AV-32260 32" TV
Need a display tuner jvc pd-42wv74
guess what? I have the EXACT same tuner that u're looking for... my place was broken into and they TOOK the tv monitor... but left behind the tuner . smart thief. if u're interested in buying this tuner to make ur tv complete again. (its in MINT condition) email me at FAIR1968LANE@aol.com and put in JVC PD 42wv74 plasma tv in subject so i d know who it was. thanks.
Feb 01, 2008 | JVC PD-42WV74 42 in. Plasma EDTV
OPERATION MANUAL
hi any look from ths site with the manual http://retrevo.com/s/JVC-PD-42WX84-TVs-review-manual/id/279ci161/t/1-2/
riz.
Nov 18, 2007 | JVC PD-42WV74 42 in. Plasma EDTV
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
JVC PD-42WV74 42 in. Plasma EDTV Logo
642 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
