Question about Cuisinart DLC-8S Pro Custom Food Processor
Motor works but will not turn on
Is the switch or lever missing? I bought this at a resale shop. Thanks susan
  • 8,596 Answers
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl asssembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Insert pusher
"insert pusher" ...this just happened to me too! Such a simple fix! ...The handle needs to face the front!.. Yes, it all clicks in nice the other way around, but if the handle is facing the rear of the unit, you will get the error "insert pusher" and the machine will not work.
Jul 20, 2014 | Breville BFP800XL Sous Chef Food Processor
My 4 cup (cuisinart)chopper grinder's motor, which grinds is burnt while the chopper motor is in good condition.Can I get the motor? How much will it cost?Is there a shop in Mumbai India where I can g
Some times it is best to get the motor rewound from a reliable rewoinding shops that are found in most places. This can work out much cheaper as ordering the motor might cost you twice the money you spend on the full unit.Also confirm if this can be brush failure , take opinion and estimate.
Rewindings shops are seen everywhere in India but choose a reputed one who can do the winding for 230 volt mains voltage with accuracy.
Nov 21, 2011 | Food Processors
KitchenAid KFP740 9 Cups Food Processor: I used my processor last in September, 2010 to blend tomatoes for salsa (it was working just fine). When I tried to use it again in Dec., 2010 it simply wouldn't...
Most likely it will be to do with the bowl or the lid. The safety mechanisms in both parts are likely culprits, they operate a micro switch just above the switch panel and hidden by the base of the bowl. Have just the bare motor plugged in and turned on with the run button depressed. Now with something plastic depress that small black button, the motor will likely start running. That proves motor is fine and you need to figure out which of the bowl or lid is the faulty part. The pusher needs to be in the lid tube before the motor will run in case you have forgotten.
Apr 09, 2017 | KitchenAid KFP740 Food Processor
Sunbeam LC6200 won't turn off. Only runs at full speed unless the bowl lid is disengaged (the safety swtich still works). Have opened it up and the Pulse microswitch seems ok, as does the rotary speed/off...
OK this is the fix for the LC6200 that worked for me. Unscrew top cover (2 screws) then another screw holding internals to external case. Carefully remove safety switch lever (use long nose pliers from the top next to lever to squeeze plastic barb that holds the levers in to the plastic body). Remove all screws on the bottom. Open and undo the drive shaft pully nut clockwise. Pull out shaft and remove belt. Unscrew motor from chassis plate. From the bottom push out the plastic speed control dial with screwdriver. Remove motor and component boards. Check microswitches. Then remove diac DB3 and replace. Remove triac BT137 600v and replace. PS I used a 800v motorola MAC228 instead. Assemble in reverse. Good Luck.
denisprod
Feb 20, 2010 | Sunbeam Food Processors
FOLLOWED MANUAL INSTRUCTIONS BUT MACHINE DOES NOT START. WHEN OWNER USED IT LAST IT WORKED. ATTEMPTED TO REFIT BUT COULD NOT GET IT STARTED. MACHINE WAS PLUGGED INTO GOOD POWER SOURCE, NOTHING WRONG WITH...
One of the major problems I have seen with food processors is the safety switch, which will not allow the motor to turn on if the bowl and top are not properly seated. The lever and/or switch sometimes wear to the point that they no longer work (easily). I'd do a bit more checking before I discarded the machine.
Oct 23, 2009 | Cuisinart Food Processors
Cuisinart DLC-85 Pro Custom 11 Cups Food Processor. Checked motor as recommended, works fine. Put together as instructed, turned on and when I press the pulse button it turns it off. Help will be...
Whoops, when putting together I failed to insert the feeder cup.  When I did that it worked!  I should have more carefully followed the assembly instructions.  Thanks for your help.  What a great web site
Apr 17, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
I have spare parts GE 4-speed Food processor model 106622f
I would like to have the lid. Please let me know how to pay you for it. THanKs
Feb 20, 2009 | GE 106622F Food Processor
Robo coupe CL52D would not turn on
There is a reed swich (safety switch) located on the top where the lid comes down. A reed switch works with a magnet. If the magnet is missing or the reed swictch is bad, no power will be allowed to the motor. Send me your e-mail & I will look up the part # in my Robot-Coupe manual. capt_rick1912@yahoo.com
Dec 16, 2008 | Robot Coupe CL52D Food Processor
Striped
The processor is manufactued by Euro-pro and you can contact them at 1-800-798-7398 give them the model # and the Country where the unit was made (Label on bottom of unit)
Feb 27, 2008 | Bravetti Platinum Pro Quad-Blade Food...
Cuisinart DLC-8S Pro Custom Food Processor Logo
241 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
