Question about Brandt Washing Machines
Top loading washing machine drum wedged halfway round
I have atop loader washing machine and a friend has just used it .Unfortunately they filled it with clothes, forgot to close the flaps onthe drum, closed the lid and set it running. The drum has spun aroundand got wedged half way round but is now completely stuck. Does anyoneknow of any way to release the drum (full of clothes) and fix it?It is a French brand called Brandt. Washer model FV 515.Many thanks, Carl.
ttech
  • 139 Answers
SOURCE: empty washing machine still unbalanced
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
Posted on Jul 20, 2007
AlmostBob
  • 550 Answers
SOURCE: Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Posted on Oct 25, 2008
  • 111 Answers
SOURCE: ERROR CODE ''SE''
sensor error The connector (5-pin, male, white) in the wire harness is not connected to the connector (5-pin, female) of hall sensor in the MOTOR. ' Reconnect or repair the contact in the connector.
Posted on Jun 26, 2009
  • 850 Answers
SOURCE: The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Posted on Jul 28, 2009
  • 11 Answers
SOURCE: My lid switch went out on my maytag atlantis
Very good reference can be found here... www.applianceaid.com/atlantis.html
Best wishes,
Bondo
Posted on Nov 12, 2009
What lime scale / detergent remover can be used for regular cleaning of my front loader.
Front-loading washing machines are energy efficient and use less detergent than top-loaders, but they sometimes have a tendency to harbor mold and unpleasant smells. By giving your washing machine a quick clean once a month, you'll keep your front-loader fresh, which means cleaner clothes, too. This eco-friendly method doesn't use bleach, costs only pennies to make, and comes together with ingredients you already have on hand.
What You'll Need:
  • 2 cups vinegar
  • 1/4 cup baking soda
  • 1/4 cup water
  • Scrub sponge
Directions:
  1. Start by mixing together the baking soda and water in a small bowl. This is going to be the "detergent" for cleaning the washing machine. Pour the vinegar into a measuring cup and head over to your washing machine.
  2. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. Set your washer to normal load at the hottest water setting. Close the door and start the machine, letting it do all the hard work for you. The baking soda and vinegar naturally break up mineral deposits and any mold growth while cleaning and refreshing your washing machine.
  3. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue. Wipe clean with fresh water.
  4. Your washing machine is sparkling clean and ready to do a load of laundry! Give your front-loader a cleaning once a month to keep your clothes smelling fresh and your machine working in tip-top condition.
Mar 20, 2015 | Washing Machines
Why does my front load washer not fill up with water like top load washers
Most modern washers use little water. Let it do a wash cycle and see if the results are satisfactory. If not good enough there is a way to allow more water to be used. Give it a go first.
Aug 29, 2014 | Whirlpool duet Washing Machines
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
How to operate top loader brandt malice AA washing machine
Hi guys! Please help me. I used the Brandt Malice top loader with a horizontal drum. I don't think the doors on the drum were clipped closed properly and now when I open the machine the drum is not facing up so I can't open it? It also won't spin. What do I do? There is clothes in there and the machine is off, but the drum seems stuck? Please help!
Sep 29, 2013 | Brandt WFH1176 Front Load Washer
Water leaking out bottom of drum. Drum does not fill up all the way and starts leaking close to halfway of filling
Contact a professional so they can properly and accurately diagnose the unit for repairs. Sounds like you have a leak in the drain lines, or the water valve.
Sep 01, 2012 | Frigidaire FEX831CS Top Load Stacked...
I have a Roper RTW4340SQ0 and my washer filled straight to the top and would not cut off it flooded my house what could this be?
There is a pocket on the side of the drum which is designed to trap air, this air pressure
in turn operates a switch to shut off the fill valve. It has a clear hose running to it and
sometimes lint will get caught in the line at the drum connection. You can open the
top control panel (usually the two screws at the base of the panel) and the panel
will hinge up. Make sure you unplug machine before servicing. The switch will be
obvious as it has one clear line and two connections on it, It is round. Remove the line
and blow into it to be sure that any lint clogging this line is cleared. Reattach and test if
you cleared a clog. If the line is clear then I would replace the switch. model is under the lid
One other possibility is that the fill valve stuck open, but I have never
seen this happen in 10 years servicing top loaders and stacks. Hope this helps. :)
Mar 31, 2011 | Roper RTW4300SQ Top Load Washer
I heard you are suppose to clean the washer once a month to prevent mold,is that true?
I have never cleaned my washer as i use bleach in with the whites when i wash. its up to you. they do make a cleaner for that.
Oct 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How to fit a belt to a wf440p washing maching
remove the top cover and lower rear cover. loop the belt over the motor shaft and then around the drum pulley, this will probably only go round halfway as it is tight, hold the belt to the pulley by turning it rather like putting on a bicycle chain.
when it's on make sure it runs centrally round the pulley adjusting the position on the motor shaft if needed.
Jan 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Kenmore HE2 #1104751. Overflows as it is just beginning to fill with water
Unfortunately - some repairs are expensive (labor wise) and not financially sound to repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 02, 2009 | Kenmore HE2 Plus Front Load Washer
Water in Drum
replace fill valve under top left rear its bleeding throw it will fix that
Nov 12, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
87 people viewed this question
Top Brandt Washing Machines Experts
Gerry Harvey
Gerry Harvey
john mabry
Are you a Brandt Washing Machine Expert? Answer questions, earn points and help others
