Question about Sony VAIO VGN-T350 Notebook
Sony VGN-T350P will not recognize new battery
I have the proper battery. When I go to power options in control; panel it says no battery found.
  • Anonymous Jan 03, 2009
    i have the same problem but with the sony &X750p
Vgn-t350p/l it has no video! Anyone help?
may be your camera is not working or its drivers are missing. check that first and then get back to me with details and some bit of its history then i will assist further. thanks for using Fixya.
Apr 15, 2011 | Sony VGN-T350P/L PC Notebook
Vgn t350p no sound
Try the steps below, this should work:
  1. Restart the computer.
  2. Check the system volume to make sure the volume is not muted or too low.
  3. Ensure the volume control dial on the left side of the front panel is increased to an audible level.
  4. Plug in a set of headphones to see if there is sound through the headphones. NOTE: If there is sound through the headphones, the issue is with the speakers.
  5. Ensure the playback device is correctly selected .
  6. Select a sound scheme in Control Panel.
  7. Reinstall the sound drivers.
  8. Check for conflicts in Device Manager.
  9. Remove all added hardware to see if it is conflicting with the sound card.
  10. Reset the BIOS to the default values.
  11. Use the System Restore utility to restore the system back to a point when the sound last worked properly.
Download and install the Audio drivers from the below link:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNT350P&upd_id=1670&os_id=7
Thanks!!!!
Dec 21, 2010 | Sony VGN-T350P: VGN-T350 Pentium M 753...
I just bought a new battery and my laptop will not charge it?
1.refix the battery
2.fully charge your battery till 100% without any interption
3.now you work with your laptop untll it would be the 0%.
4.Kindly repeat the steps four times.
5.After that you Defently feel,your battery backup will increase.
Nov 17, 2010 | Sony VAIO VGN-T350P/T Notebook
How to replace a lcd screen on a sony vgn t350p
Hi. Here is a graphical instruction to disassemble your laptop and replace LCD screen. http://laptoprepair.ca/news/11776.html
and here is the service manual in case you need more info.
http://www.notebook-manuals.com/laptop-manuals/service_manual_for_SONY_VaioVGN_T350P_9e406957d4_VGN-T350P-manual-repair.pdf
Good luck.
Jun 12, 2010 | Sony VAIO VGN-T350P/T Notebook
Power is erratic. Shuts off randomly.
it could be caused by a lot of things. isolate it first. since its randomly shutting down, try first in normal mode. does it heats up before it turns off, if yes its an overheating issue. you may need to replace fan or even motherboard of your pc. have you checked your battery? is it properly seated? or is the problem happening when your system is plugged with the ac adapter? try to check the power cable.
Apr 06, 2010 | Sony VAIO VGN-T350P/T Notebook
My sony vaio vgn -T350P , when I turn it on, I
hi, it may be a ram or processor problem you may need to replace one of them
Jan 17, 2010 | Sony VAIO VGN-T350P/T Notebook
No sound
Try going into device manager
click start
then control panel
then system
they hardware
then device manager
if there is a yellow !mark next to sound then use the properties tab to reinstall the the driver
Hope this helps
Nov 28, 2009 | Sony VAIO VGN-T350P/T Notebook
Where is bluetooth module in sony t350p?
Typically, the blue tooth modules are found in the same compartment as your RAM.
Let me know if you can't find it...or look at your owner's manual
Apr 13, 2009 | Sony VAIO VGN-T350P/T Notebook
I need to replace the keyboard in my Sony VAIO VGN-T350P. Where can I get an OM keyboard, and instructions on how to replace it?
These folks sell a replacement keyboard for your model.
Either the accessory or user guide on Sony's site should provide you with instructions for replacing it.
Mar 31, 2009 | Sony VAIO VGN-T350P/T Notebook
Sony VAIO VGN-T350 Notebook Logo
642 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
