Question about Mitsubishi WT-42315 42" TV
Red and green lamps look off center
Once my tv gets warm the red lamp pushes to the right creating a green band 2 inches wide down the left side of the tv. this also causes a ghost image, one green, the other red. the problem has corrected itself last night so i dont think heat has to much to do with it, however when i turn the tv on after being off for awhile it is fine. 2 minutes in the red shifts to the right and hasnt gone away today? Any pointers?
  • 1 more comment
  • jesse fort May 09, 2007
    Okay, my description sucked. Basically the red lamp looks like it is shifted to the right two inches and sucking into the center on the left side and spreading out towards the right. In the middle it is converged okay.
  • Anonymous Nov 06, 2007
    My TV just started doing the same thing. It was also purchased around 10/2003. It shows the green band and the red band ghost images. If you turn the TV off, and then back on, it corrects itself, but sometime it does it again. I have not seen it do it while watching a DVD as of yet though.
  • Anonymous Feb 18, 2008
    same here
    Genius:
  • 1,694 Answers
Intermittant convergence alignment issues are quite common.
Either solder the convergence IC pins or better yet , change out
the IC's with first quality OEM spec or upgrade..............T.
Posted on Apr 04, 2008
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
My tv turns on, but there is no picture. The two green lights and one red light are flashing on the button in front. What do I do?
That means that the lamp may be defective and the TV needs service. You can replace the lamp yourself. The code is on the right side of the TV and on the lamp case. Get a replacement using this code from the store where you bought the TV or a Samsung Service Center.
Once you have the correct lamp (the wrong one may damage your TV), make sure your TV has been off for at least 30 minutes (cool down). The cool down will not happen properly if the TV is plugged into anything other than a wall outlet.
Open the lamp case and take out the old lamp and replace with the new one. Do not touch the glass with your hands and do not insert any objects into the case. Do not leave the old lamp near flammable objects or where children can access it.
I hope this helps.
Apr 13, 2010 | Samsung HLS4266 TV
3 problems 1. TV shuts off and on automatically. 2. 2 inch band on left side of screen 3. No picture at all
The band or shadow on the left side of the screen definitely sounds like a defective light tunnel.As for the intermittent pix and shut down this could be the lamp if you have not already changed it.
Oct 15, 2009 | Samsung DLP HL-P5663W 56" TV
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Green spot / glow in center left side of Panasonic PT-61LCX65 LCD Projection HDTV
This unit has a chonic issue with corruption in the eeprom that causes spots and shadows. The correction is to find some service center that has the jig to hook up to your unit and correct the eeprom. This is an extended warranty issue with Panasonic and if you contact them they should be able to refer you a qualifed service center and Panasonic will pay.
Apr 06, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Samsung HL R5067W Problem
You have a bad Light Tunnel in the Light engine, you can replace the engine, or try to replace the tunnel.
Jul 31, 2007 | Samsung DLP HL-P5663W 56" TV
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Arched picture at bottom seperating the green and red
Your tv has a convergance failure. the convergance ic's need to be replaced. Upgraded part # STK392-150 or STK392-160. Both ic's should be replaced to prevent future failure of other colors.
May 20, 2007 | Toshiba 43H70 43" Rear Projection...
Mitsubishi WT-42315 42" TV Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
