Question about Equipex PZ-330 Electric Single Oven
Last night we were cooking on our Whirlpool Electric Range, Model #RF366PXDN. Sparks and smoke shot out from the burner knob. What might be the source of trouble & how might we repair the problem without purchasing a whole new Electric Range? Thank you for your assistance, S.B.
  • 2,920 Answers
You have a short in the electrical and i suggest you call a service repairman to have it looked at but he will probably tell you to get a new stove,,,there is no simple solution to this
Posted on Jan 01, 2009
Electric Oven will not heat or come on
Sounds like you have burned out the element?
Aug 12, 2015 | Ovens
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
My Whirlpool kitchen Range is Model # SF 3300 EK40, and the left side Igniter (IGNTR Surf) no longer sparks when either of the left side top burners are turned on. Instead, the right side Igniter sparks,...
You are right it is the igniter that is bad and should be replaced. Please check this video on how to replace it:
Hope this helps...please post back for further assistance.
Feb 14, 2011 | Whirlpool Ovens
My Frigidaire FEFL79GSA cooking element is intermittent. Last night it went to high although the control knob was on low and would not turn off when the knob was turned off. I had to turn the breaker off...
I'm banking that infinite switch is bad (the knob) but there could be other issues. If it's just one burner doing it then I would assume the switch, but if not then I would get a technician.
Hope this helps, good luck...
Dec 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven and coil burners work one time then the next time neither one warms up, try again later and it works again. started last week when the oven preheated put in food to cook and half hour later noticed...
If this is an electric range, it sounds like you are not geting 220v all the time. check were your cord or house power hooks up to range. You may find one side of the 220 line burnt. Shut off power and repair conections. or call a qulified tech.
Nov 22, 2009 | Ovens
I tried to cook a frozen pizza in my Tappan electric range last night (which required it to be preheated to 400 degrees) and it would not preheat at all, even after about a 3 hour wait. I just turned up...
your looking for part number 67 on that part breakdown
it is the bake element and if you inspect it im sure you will find it cooked or broken
befor you actually order the part take the unit out
unplug it
and inspect your wire connections to both sides of the element
Oct 17, 2009 | Tappan 30IN ELEC IGNa Oven
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Equipex PZ-330 Electric Single Oven Logo
76 people viewed this question
Top Equipex Ovens Experts
Dan Webster
Dan Webster
Are you an Equipex Oven Expert? Answer questions, earn points and help others
