Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Fdw60 starts but stops soon after
Any program i select the washer sounds like it fills with water and then begins the wash cycle, soon after (time varies between 10 and 30 secs) it makes a beep then the eco and prewash lights flash and the machine begins the drain which it completes. please help
  • 1 more comment
  • xxdemidychex Jan 02, 2009
    i have the same problem i took the back of the machine of and guess what no access to hoses
  • Anonymous Jan 03, 2009
    i have the same problem,sounds like it is filling, then 4 beeps and the fast wash and prewash lights flash together and nothing happens just bought it yesterday, seems like a common problem
  • jimjamjo Apr 17, 2009
    Identical problem. I had a spare timer board which I replaced but made no difference
In my case it was the pressure sensor on the side of the short hose between the main (circulatory) pump and the bottom jet arm (which spins inside the machine)
Remove it and test resistance on terminals while blowing into the tube.
There is another pressure sensor on a hose attached to the waste assembly but appeared to be working correctly.
Posted on Apr 21, 2009
  • 979 Answers
I think I would call the mfr or dealer and let them look at it. I tried this on a similar product and found they were able to help me at a cost that was surprisingly low. They ended up replacing a board that wasn't that much. This sounds more like a software than a hardware problem. Spend the money and be done with it.
Posted on Jan 11, 2009
My washing machine stopped working in mid-cycle. No agitation is going on and I could not drain it but putting to spin.
Make sure the washer fills with cold water from the beginning of the cycle because most washers have a cold only rinse cycle and if your cold water valve is bad then the machine will stop mid cycle because it cannot fill the washer for the rinse cycle. Secondly, it helps to know which washer you have so please enter more info next time you ask a question. Good luck.
Jun 28, 2015 | Whirlpool Washing Machines
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Washing machine will fill with water but the wash cycle will not
Sounds like the rotary timing mechanism is broken, this can be replaced but is really expensive, and you are left with a new component in an old machine.
Start on this program, then push in and rotate to another program,pull out and that should take over.
Mar 12, 2010 | Maytag PAV2300 Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Soon as i set cycle and swich on door light flashes open
hi,
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
566 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
