Question about Baume Et Mercier Riviera MOA08467 Wrist Watch
Knob problem i unscrewed the knob on the side of hte watch to change the date and time and now it will not sit flush on the side of the watch. i tried to turn it both clockwise and counterclockwise and nothing is happening. Does anyone know how to fix this?
    Sniper:
  • 51 Answers
Please give me a better idea about what is happening.Does the crown screw down at all? email me donald@finewatchmaking.com
Posted on May 08, 2007
How do I change time and date on timex indiglo
  • How to Set Dial Indiglo Watches
    • 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
    • 2 Pull the knob out from the watch slowly until it clicks into the first position.
    • 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
    • 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
    How to Set Digital Indigo Watches
    • 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
    • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
    • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
    • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Read more : http://www.ehow.com/how_5758168_set-timex-indiglo.html
    Mar 31, 2015 | Timex Indiglo Watches
    How can I ajust date (day and month)? AR0709
    Usually to change the date and time with a watch you pull the knob out on the side half-way instead of the entire way. When it's pulled out half-way, that should let you turn it to change the date and time.
    Mar 10, 2011 | Giorgio Armani Emporio Armani Classic...
    My wrist watch has been in a drawer for over a year. I want to wear it now. the time shows 6;13 and the date shows 8: 16. It is running correctly. How do I set it foe the correct time and date?
    First you need to unscrew the crown (setting knob) of the watch. Turn dial from up to down (downwards), you will feel the knob loosen and then it will pop out gently.
    Pull out the pin very gently and turn downwards to set the date. If you have a Day and Date watch, turn upwards to set the day of the week.
    To set the time, pull the pin out futher and turn to set the appropriate time.
    Finally push pin in and simultaneously turn upwards to screw back the pin.
    Please make sure you push turn the pin tightly because most cases of Water Damaged watches are caused due to the pin being screwed up not tight enough.
    Aug 17, 2010 | Watches
    How do you set the day of the week?
    Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
  • Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
  • Step 2 Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
  • Step 3 Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
  • Step 4 Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
  • Step 5 Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
  • It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
    Aug 11, 2010 | Watches
    Cannot pull the knob out, to change the date and time on ny TAG Heuer Formula 1 CAC1111-0
    Some watches need to have the crown unscrewed.
    Try turning it anticlockwise then pull out.
    If this doesn't solve your problem, go to the TAG site "tagheuer.com" and find your nearest dealer.
    Mar 07, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
    How do I set the date
    The knob on the center/right "unscrews" if you turn it counter clockwise. This will allow you to pull it outward: Do so one click's worth. Then turn the knob in reverse. This advances the days one at a time. Push back in and screw knob back in until snug.
    Nov 19, 2009 | Festina Chronograph 16162/1 watch
    Can't pull out knob on side of watch to change time
    You may have screwdown crown. Try to unscrew it first and then pull out. If the crown is turning but you can not pull it out, there is a rust in the watch and you will have to find your nearest watchmaker to sort that.
    Rate, please.
    Mar 28, 2009 | Invicta 2636 Ocean Ghost Chronograph Watch
    Tag Heuer watch
    The knob is a screw-cap seal. When closed (screwed in) it closes the chamber to prevent water from entering the watch.
    You will need to unscrew it. It should snap out. In this position, you can wind the watch. Pull the knob out one click, and you can adjust the date. Pull the knob another one more click, and you can adjust the time.
    Push the knob back in. In order to seal the watch back up, you will need to push the knob in while turning the knob. You will know you did it correctly when the knob will not turn any further.
    Good luck.
    Dec 25, 2008 | Tag Heuer AquaracerWAF1110.BA0800 watch
    Tag Heuer Ladies Professoinal 2000
    Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
    Mar 15, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
    Tag Heuer Aquaracer calendar problems
    You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
    Aug 24, 2007 | Tag Heuer cj1110.ba0576 Wristwatch
    Baume Et Mercier Riviera MOA08467 Wrist Watch Logo
    130 people viewed this question
    Top Baume Et Mercier Watches Experts
    Ansel Alberto
    Ansel Alberto
    Marvin
    Marvin
    Are you a Baume Et Mercier Watch Expert? Answer questions, earn points and help others
