Question about Denon DP-47F Turntable
Turntable speed erratic
My denon DP-7F (20 yrs old) direct drive "drags" when first turned on, but only in one spot per revolution. After about the first 20 minutes a 45 rpm will play O.K. but it takes about an hour for an L.P. to play correctly.The unit has not been used that much.
    Genius:
  • 1,175 Answers
Hi...
It doesnt sound like it's related to an Auto function ( auto lift tonearm end of LP lift)
so...The motor is the only issue.
It could be the motor drive circuit or the motor.
It's fixable by a qualified tech.
I'm not sure what it's worth to you though.
Posted on Jan 19, 2009
    President:
  • 948 Answers
It is likely that grease has hardened and as the gears rotate that grease is interfering with normal operation. Take the unit apart and have a look at the drive mechanism, if there is something in the gears you should be able to see it.
Posted on Jan 01, 2009
How do I get a schematic for a DP1100 denon turntable?
http://www.vinylengine.com/library/denon/dp-1100.shtml
Jan 19, 2015 | Denon Audio Players & Recorders
Denon DP 300F turns extremely slowly.
If like what you say the deck is brand new you should contact the service center. They will attend to the matter free of charge. Web address follows:
http://denon.custhelp.com/
Dec 13, 2014 | Denon DP-300F Turntable
How to adjust dp-300f speed
Both the owner's and the service manuals for your turntable are available for download:
http://www.vinylengine.com/library/denon/dp-300f.shtml
You only need to register (free) with them.
May 28, 2014 | Denon DP-300F Turntable
Denon dp-7f sounds fuzzy
This could be caused by a poor earth wire connection to the cartridge.
Jan 12, 2014 | Denon Audio Players & Recorders
Denon DP-7F subweights
I don't know what you are referring to as sub weights. Everything you need is already on the tonearm.First you have to balance the tonearm, then you adjust for stylus pressure and anti-skating. For more information, please my website at audioserviceclinic.com. Thank you.
Nov 23, 2013 | Denon DP-47F Turntable
I have a denon DP-7F direct table (1989)ust wondering about the point of the arm the head of the cartridge housing is very close to the record any way to get that adjusted higher?
If the tonearm balance and tracking force for your cartridge are adjusted correctly, ignore it.
Register and download the manual for free at vinylengine.com
http://www.vinylengine.com/library/denon/dp-7f.shtml
Eeeww, page 8 says the counterweight snaps on and the tracking force is factory set. Any self-repecting turntable should have precise manual balance and tracking adjustments. Or your counterweight is not on? Either way, I'd look seriously at getting the stylus checked for excessive wear if it's tracking too heavily. The manual says 500 hours of normal use. You'll be carving up your recordings.
Maybe post the question to the guys at Vinylengine
Apr 30, 2011 | Audio Players & Recorders
Denon turntable DP 26F turntable doesn't turn
through the platter motor access window, unhook belt from motor spindle (usually brass) which is exposed on the left side when you remove the mat.
Now give the motor a spin with your thumb/index finger. repeat up to maybe a dozen times. sometimes a motor like this will get a dead spot where a bit of debris will 'gum up the works' and stop the electrical contact it needs to spin.
if it does start working by some miracle, then just let is sit and run at 45rpm for hours or even days, this may kinda rub off some very light corrosion that might have built up on the armature over the years. (if it is a brush type motor)
Jan 08, 2009 | Denon DP-26F Turntable
I have a Denon DP-51F Turntable that recently developed a speed control issue when playing. I noticed the "lock" indicator also flickers when the speed becomes erratic. It's direct drive, and I...
Hi. I also have a DP-51F and am experiencing severe problems with tracking. My sense is that the tone arm may be damaged. Would you be willing to sell parts from your turntable if you're not going to repair it? Let me know as I would be interested.
Oct 21, 2008 | Audio Players & Recorders
Platter turns slow
This turntable design has a direct drive system instead of belt drive (two types). If this unit has been in storage for some time, it has most likely been at hot or cold tempuratures - not good for any electronic/mechanical system.
My guess is that the direct drive motor needs to be rebuilt - internal friction is probably keeping it from operating at proper speed. Best to consult with a repair shop that can handle direct drive turntables - several on the internet, if you cannot find one locally.
BTW: You can find a manual for this at : http://www.vinylengine.com/library/denon/dp-45f.shtml
Best regards,
Andre
Apr 06, 2008 | Denon DP-47F Turntable
Belt came off
Remove the rubber mat and you will see two holes in the turntable. Put your fingers in these holes & using equal force pull up to release the turntable. The drive belt goes around the metal disk you will see below and around the drive pulley. Most likely it has just jumped off the pulley so hook it back over. Replace the turntable and gently rotate it a couple of revolutions, you can see the belt through the holes in the turntable. If all is seated OK power up & enjoy! You can download the manual from the link below: http://usa.denon.com/DP29F_DFU_ownersmanual.pdf This shows the procedure as per original install. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 13, 2007 | Denon DP-29F Turntable
Denon DP-47F Turntable Logo
500 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
