Question about Mini Motorized Bike
My 50cc mini bike starts then dies 5 secs after starting. why?
i also have to use excessive amounts of starting fluid and the bike starts kinda idles up and down then dies. yesterday it would start but when you pulled the gas it wouldnt go anywhere but didnt die. why is this? why does it die? when it was starting and running but not goin i figured it was the carburater but im not sure. if you guys can figure it out for me and let me know that would be great because i am 17 and just now learning about all this auto part stuff lol... thanks
  • 148 Answers
It sounds like you may have 2 problems
  • Bad gas
  • dpossible loose spark plug( bad compression)
dump out the gas put new in
Remove the spar plug and examine the plug if it is wet and black it is fouled
if it is white ad dry it is not getting gas
If you can replace the spark plug if not just clean it with a wire brush put back in and tighten
Finally make sure the spark plug wire is not lose
Best of luck to you
Posted on Jan 01, 2009
Clean carb and jets and new plug or gap it at .35 and 93 gas
Posted on Oct 07, 2012
I have the same thing except mine rides for about 5 minutes then dies.?
Posted on Aug 12, 2012
Sounds like youre being starved of fuel, stripping down the carb and checking float levels and carb/fuel setup could help?
Posted on Jul 11, 2009
Hi, my little boys 50cc mini kolt will not rev up enough to go. Guessing this is air flow problem as if the choke is switched on it cuts out completely.
Hi, Clare and the usual suspects are:
1. Severely drained or faulty battery.
2. Faulty regulator/rectifier or high output coil.
3. Faulty power valve, solenoid or installation.
4. Clogged air filter or exhaust.
5. Cracked or incorrect float level.
6. Float needle is not seating.
7. Faulty reed valve.
For more information about your question please visit the website below. Good luck and have a nice day.
Thread Aeon Mini Kolt 50 Dies Under Load
Scooter Troubleshooting Scooter won run All about Scooters
Fix your Mini bike Carb bogging cutting out etc
Jan 15, 2016 | Motorcycles
Hi, anyone know what the factory carb settings are for an aeon mini kolt 50cc. Having problems with getting it started, changed spark plug and battery
Two-Stroke Scooter / ATV Carburetor Settings And ...
? 4:37
Jun 2, 2012 - Uploaded by 90GTVert
Part 2 of a 4 part video detailing all of the basic settings and ... Two-Stroke Scooter / ATV Carburetor Settings ...
Fix your Mini bike Carb - bogging, cutting out etc - YouTube
? 4:51
Aug 15, 2011 - Uploaded by Cpt MishMash VonRandom
If you are having trouble with your mini bike/quad whereby its difficult to ... Two-Stroke Scooter / ATV ...
quad 50cc carb Questions & Answers - Fixya > Forum > Tags
50cc carb wondering what the factory setting is for a 2002 50cc Kawasaki kid's ...aeon mini kolt 50cc quad will rev a little then cuts out no power Likely a lean ...
Aeon mini kolt 50cc quad will rev a little then cuts out no ...
Jan 05, 2016 | Factory Motorcycles
Direct bikes 50cc scooter wont start
If this is a new ride, return to the dealer for help. If yo do anything, you will void your warranty. Go back and get a complete run down on the operation of this machine.
Mar 09, 2013 | Motorcycles
My 50cc cpi aragon 2007 model moped was running fine up untill 2 weeks ago i turned the bike off outside my house i then went out side to start it and it wouldnt start it cranks over but the coil does
may hav a bad or connect issue with coil--or magneto cud be problem--chec out entire ignition system--purchase an engine manual on that model--also library sec 629 has many vehicle books
Feb 20, 2013 | 2007 Cpi Aragon GP
Pull start assemmbly for a 50cc engine
need diagram of how to put the pull start back in to the housing
May 17, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
Got a kazuma 50cc quad have problem starting it when i finally get it going it wont take any throttle without cutting out.
i have i 50cc ATV quad and we have done every think to it and it still won't start but the fuel isn't going to the spark plug any one know what to do. ?
Jan 09, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Bike wont run for more than 5 secs and thats when it does start
Not sure but it sounds like it's running too rich a mixture and/or your float levels are not adjusted properly. When you stopped the excess fuel has gone into the bore not burned which will wet your spark plug making it very difficult to start. Depending on the colour of the smoke it could also indicate that your mixture is too rich. For extra power you need more air not necessarily more fuel. I hope that helps you. Again not sure but sounds like that is your problem. :)
Sep 27, 2009 | 1988 Yamaha TZR 250
There is power to switch
I have a youth atv eng.152fmh right below that # is*51019044* dis.107ml om front is lhjschl1458009086 i need to wire it back up has been took apart where can i fiend a ezy wiring die.
Mar 22, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Mini Motorized Bike Logo
894 people viewed this question
Top Mini Sport & Outdoor - Others Experts
Are you a Mini Sport and Outdoor - Other Expert? Answer questions, earn points and help others
