Question about Smeg SE250XUK Stainless Steel Electric Single Oven
Light bulb How do I change the light bulb in my SMEG SE250XUK Oven, Do I have to pull it all the way out and take the back off or is there an easier way
  • Anonymous Mar 22, 2014
    cannot remove cover
    President:
  • 1,462 Answers
For most smeg, the bulb cover just unscrews as does the bulb and the bulb is a heat-proof small edison screw type
Posted on May 07, 2007
Smeg SE250XUK only oven light works, no fan no heat please help
door switch defective,,try to open close again & again
Feb 12, 2015 | Smeg Ovens
Fan forced element is broken in my Smeg SA301X. I'd like to fix it by myself. I opened the cover in side and measured the element. there are 3 screws fixing element on the back wall. one in the bottom...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 17, 2011 | Smeg SE250XUK Stainless Steel Electric...
Oven not working but grill is please help
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please
How to Video Tutorials on Domestic Appliances
Dec 12, 2010 | Smeg SE250XUK Stainless Steel Electric...
Need to know what symbols on dial control of smeg sa210x
can't hepl you with that one but turn ff power and open the control panel . inside should be a tec sheet that will tell you the answer.. mm
Jul 14, 2010 | Smeg SE250XUK Stainless Steel Electric...
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
SMEG SUK62 MFX
check stat is not open circuit and check selector switch not damaged
Oct 18, 2008 | Smeg SE250XUK Stainless Steel Electric...
SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
Dec 07, 2007 | Smeg SE250XUK Stainless Steel Electric...
Smeg SE250XUK Stainless Steel Electric Single Oven Logo
1,163 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
