Question about Sony VAIO VGN-N110G/W Notebook
Sony Laptop VGN-110G won't power up
The above laptop won't power up on AC adapter.
Apparently the battery won't get charged either because of some thing inside the lap top charging circuit. The last time the battery had any juice left, I started the laptop on batteryonly. The machine started booting up and died may be because the battery was low.
Questions.
1. Is there a way to charge the battery externally and then try to boot to see if the PC starts. This way I know that the PC works on battery and there might be some thing with the charging circuit.
2. The power adaptor is fine and I measured the voltage and its fine.
3. What does it take to replace the borad inside and is it available in the spare market. I am reasonably well versed with electro-mechanical stuff and with goood instructions and dos and donts can replace parts.
ned help please.
Thanks.
Chan9
  • alondra06 Jan 24, 2009
    I have the same problem and no one seems to know the answer to it...
  • lyss8 Mar 16, 2009
    I have the same problem as well.   No idea how to fix this.
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Sony vaio not charging while charger plugged in
Seemingly your laptop dc jack is dead. How to confirm it? If you should wiggle your laptop charger on a position to let your laptop charge, it indicates your dc jack is loose. Either replace it or repair it. If your dc jack works well, please check your ac adapter. Maybe your charger is dead.
http://www.chargerbuy.com/laptop-ac-adapter/sony-ac-adapters.html
Oct 27, 2012 | Sony VAIO VGN-NS160D/W Notebook
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
Is there a software that is associated with my sonny battery that will make it charge again
If you plug in your AC adapter to your laptop to charge the battery and get the "plugged in, not charging" message then try the following solution:
  • Disconnect AC adapter
  • Shutdown laptop
  • Remove laptop battery
  • Connect AC adapter
  • Power on laptop
  • Click the Startup Menu
  • Type Device and select Device Manager
  • Under the Batteries category, right-click Microsoft ACPI Compliant Control Method Battery and select Uninstall.
  • Shutdown laptop
  • Insert laptop battery
  • Power on laptop
    If you follow these steps and find that your laptop still does not charge then consider replacing the laptop battery itself.
    Hope to have been of assistance,
    Thanks.
  • Sep 14, 2011 | Sony VAIO PCG-K23 Notebook
    Dell Inspiron 1521 battery not charging
    Laptop batteries power a laptop when it is not connected to an electrical outlet. If the laptop battery fails to charge when the laptop is plugged into an electrical outlet, the battery is likely dead and needs to be replaced. Unfortunately there is no way to fix a dead battery. However, while a dead battery is the likely cause, it is not the only cause. The AC adapter may be broken, in which case the battery won't charge, or the battery contacts may be dirty and need cleaning. Prior to replacing the battery, perform simple tasks to ensure a dead battery is the cause of the problems.
    1.Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
    2.Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
    3.Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
    4.Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
    5.Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
    6.Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
    7.Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
    Sep 01, 2011 | Dell Inspiron 1521 Laptop
    Laptop power charging stops and laptop later shuts down and no charging
    First you should figure out what caused this problem. Here below are some possible cause:
    AC Adapter Problems
    If the AC adapter is not working properly, then the charging won't occur at all. An AC adapter, with lower than required voltage settings, will not be able to charge the battery. See to it that the AC adapter matches the laptop battery's requisite settings. A loose wire or internal breakdown, may render an AC adapter useless. Changing the adapter all together might solve your problem.
    Acer Aspire 5720 AC Adapter
    Power Management Software Problem
    Sometimes, the problem is merely with the power management software. This is the classic case, when the laptop charges when switched off, but doesn't when the computer has booted. The software may have gotten corrupted which must be causing the problem. In such a case, go to the device manager section and uninstall the power management software. In case of Windows XP, uninstall 'Microsoft ACPI Compliant Control Method Battery listing' from the device manger section. Take care that you do not install any other AC adapter driver software. Then go for a 'hardware scan', which will automatically identify the battery and reinstall the latest version of the drivers again. That will restore the charging facility of your laptop.
    Internal Charging Circuitry Problem
    If neither the AC adapter, nor the power management software has a problem, then problem can be with the internal charging circuitry of the laptop. In this case, there is little you can do, other than send the laptop to the manufacturer's service center.
    Bad Battery
    If you have checked for all of the above, one of the main reasons, which could lead to the problem of laptop plugged in but laptop battery not charging is a bad or dead battery. Run a laptop battery test. If your laptop is quite old, this could be one of the most likely reasons. Get the battery checked from the manufacturer and check if it has exceeded its predicted recharge cycle limit. It is important that you get the dead battery replaced immediately with a new one. Laptop battery troubleshooting will solve the problem.
    Hope this will help.
    May 09, 2011 | Acer Aspire 5720-4230 Notebook
    Laptop battery and AC adapter
    Replace the power supply first, chirping is not good, and if the supply has a low output it could be putting out just enough to run the machine and not enough to charge the battery. Starving the machine for power can damage the machine or the battery, so, you may still need a battery, but you won't know until you replace the supply. If you do need a battery, aftermarket or generic batteries are fine. I've used them and had no problems. Many times you'll find that the aftermarket batteries are made by the same company that the laptop manufacturer uses, they just don't have the label, it's this way with damn near all the laptop manufacturers.
    Jul 29, 2008 | Sony VAIO VGN-N130G/W Notebook
    Sony Vaio ac adapter submerged
    If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
    If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
    Thanks
    Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
    Sony VAIO VGN-N110G/W Notebook Logo
    268 people viewed this question
    Top Sony Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    laikexpert
    laikexpert
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
