Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
The pull cord on my toro powerlite snowblower wont retract
About 10-12 in. of pull cord remains outside the blower. Can I fix it? Joe
  • 2 more comments
  • Joehenry Jan 04, 2009
    I guess I should have asked How can I fix it. I don't think the spring is broken as the pull cord will recoil partially. Thanks Joe
  • Odieee Jan 19, 2009
    The pull cord on my Toro snowblower is limp--no resistance, so no start.  The technician said the starter something was frozen.  After an hour indoors, the problem disappeared.  But it returned and so the Toro (which means "bull," no?) is in an unwelcome presence in my kitchen.
    Is there a solution?
  • Anonymous Mar 13, 2014
    pull cord feels too tight. ran it into snow bank that was hard and icy(oops) and now it won't pull.
  • Anonymous Mar 27, 2014
    how do i repair a non-retractable pull cord on a troy bilt blower?
My pullcord won't retract
Posted on Feb 04, 2009
    Genius:
  • 1,061 Answers
YES YOU CAN JOE,Your recoil has come undone or the spring broke. but it can be fixed.richardm69
Posted on Jan 01, 2009
  • Desktopsbyduck-Computers
    hey joe. ok spring is still good rope sometimes comes off pulley remove and rewind.becarefull its soring loaded.ty for the vote have agreat new year.RICHARDM69
Install scarper blade toro powerlite mod. 38182
On everyone I have ever seen, there are just three bolts that go through it into the auger housing. There is a notch that the scraper has that fits on to the end of the housing. You can see the drawing for it here - http://www.partstree.com/parts/?lc=toro_consumer&mn=38182%2C+Powerlite+Snowthrower%2C+2009+%28SN+290000001-290999999%29&dn=3358-429-383366-0008
I just picked one of the models for 38182 cause i think they are likely all the same, but if you want to be sure, use the list here - http://www.partstree.com/parts/?lc=Toro+Consumer&mn=38182 and choose the one that matches your serial number range. Then select the drawing to see the rotor assembly. Should be pretty easy except sometimes the heads of the bolts to keep the scraper on get wore down if the scraper bar wasn't changed when it should have been.
Jan 09, 2015 | Toro Power Clear 210R Part 38587
Have no spark to plugs
Those sensors have no effect on spark. Did you replace the plug, if not remove it hold it against the engine, have someone pull cord, watch for spark. If you have spark then you have a fuel problem. If no spark then after replacing plug, then remove stop wire from magneto side. Pull cord an watch for spark. If no spark then remove housing an flywheel, measure gap between mag an flywheel. Check to make sure magnets are still on flywheel. Call some shop or check a service manual on gap setting. If no spark still you will need to replace the magneto. This is rare an its is more likely a plug that needs replacing. Toro snowblowers are nice machines, this is not a hard fix. Really to tackle this is starting with the plug.
Mar 16, 2014 | Toro Snowblower 826 Oxe 38624w With 3 Year...
Toro snowblower wont start. seems like the fuel isnt getting into carb.how and what can i do
Reference your toro snow blower. does it start and run for a few swconds then die. if so It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now.
Oct 21, 2011 | Toro Lawn Mower With Toro Power Tools
Toro snowblower wont start.I have a toro ccr powerlite that dosnt seem to be getting fuel from the fuel line into the carb. I took the fuel line off and fuel is getting to the carb so then i removed carb...
Reference the Toro snow blower. It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now. Hope this works for you.
I have a toro snowblower. i cannot pull the pull cord. it feels like it is stuck.
Pull your spark plug out and see if the cord will pull out, if it does than that means your cylinder is full of gas which is a result of ethanol in the gas causing the needle valve to leak causing fuel to siphon from tank to cylinder, pull your carb off and put a carb kit in and you will be blowing snow in no time,if this isnt the problem then enjine may be seized up and its time to replace blower. Good Luck!
Oct 07, 2011 | Toro Lawn Mower With Toro Power Tools
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
How to change spake plug on powerlite snow blower
Remove the two screws holding the control panel to the machine. The spark plug is behind the panel.
Dec 23, 2008 | Toro Blowers Rake and Vac - Electric...
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
1,942 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
