Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
KDF-60XS955 recycles after a few hours of use
After few hours the TV goes into a recycle mode and the green light continues to flashes until the picture comes back on, this will continue to happen. If I shut the TV off completely and let it rest for a while I can watch TV for a few hours with no problem? I have read in the past that this is caused by the lamp and replacing the lamp will fix the problem, I am afaid if I spend the money on the bulb and this was not the problem.
  • Sony Master
  • 5,138 Answers
Pull your Lamp out and look to see if looks blowed. More then likely Lamp is Problem / lamps $119.00 Acme Has Them call 1-800-575-9833.
Posted on Jan 01, 2009
Turn the tv on and the green light blinks and then turns off and comes back on then turns off again but the screen is black. What is wrong?
KDF 60XS955 intermittently turns off green light blinking then on after...
The frequency and color of the blinks will indicate the issue. There is a hold-down button sequence to try to backdoor your way into the set to see if the panel will light. You may have simply racked up too many "weird tuner faults" and need to reset it. My suspicion is that it's either that or bad panel backlight.
Unplug set, press and hold (on set) volume-down and channel-down and hold them while pluging in set. Will come on with "k" on screen, or will crash again if backlight bad. If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter. Let set recycle to green and unplug/re-plug in 5 seconds: the set should be in OOB state
ref:
Sharp lcd tv power button flashing
Feb 13, 2016 | Televison & Video
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Lost picture and sound
You likely have a bad lamp. The symptom you describe matches a weak or old lamp. When you first turn on the TV, the lamp is cold and doesn't draw much power. But old lamps usually have clouded reflectors, so the reflector doesn't reflect the light, it converts it into heat. The bulb overheats, draws more current than allowed, the TV "recycles", green light flashing and then the process starts over. Replace the lamp, use and original Sony lamp as the aftermarket lamps are known troublemakers. Please be sure to rate this solution. Thanks!
Nov 09, 2008 | Sony KDF-42WE655 Television
SONY 60" KDF-60XS955 power goes off and on every 30 sec
..got the lamp changed too..back to be where it was before, working perfectly good...saved a lot of mone from having it serviced at home...thank you all for the info....
Dec 08, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Continueus green flashing light
i have seen weak lamps do this. this would also be the first thing the servicer would replace. worse case scenario you would have a spare lamp on hand...
Oct 11, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
49 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
