Question about Sony Handycam DCR-HC28 Mini DV Digital Camcorder
Sony Handycam DCR-HC28 Re-attach the power source
I keep getting a re-atttach power source C:32:10 message, every time I turn it on. How do I stop or correct this.
  • Anonymous Jan 29, 2009
    helppp
5 Suggested Answers
SOURCE: sony handycam dcr-trv19e mini
Thank for that qestion,
At this point, if you are a lay-man or person you need to eject the camcorder and aloud it open and put under sun light for an hour. If its do the same, take it to a technicain.
but if you are a technicain, dismantle the camcorder and put the machinusm under hot tempreture for 20minute. then mount it back and your camcorder will be fine.
I have done this time and again and it has never fail me.
I hope you will smile.
Posted on Jun 11, 2008
  • 4234 Answers
SOURCE: Sony Handycam DCR-TRV22 camera
The C32:10 error indicates that a motor is not running as it is supposed to. I don't have the manual with me at the moment, but usually this is one of two possibilities:
1) The video heads are not spinning. This is a failure of the head/drum assembly that might be something simple. But, this is not a repair that should be attempted by someone that has not repaired cameras before.
2) The takeup reel is not spinning. This would cause the tape to collect inside the unit ruining the tape and possibly damaging the mechanism.
These units have built-in sensors that detect the correct movement of these parts. If no movement is detected, the unit will eject the tape and shutdown displaying the message you see. This is to prevent damage to either the tape or camera.
This unit should be brought to a Sony authorized service center for repair.
Dan
Posted on Nov 06, 2008
SOURCE: i have a camera sony dcr-hc51e, (c:32:11 problem)
actually 32:11 is related to the casette compartment error.
reset the camcorder.
if the problem perist then you had to go to the service centre as mechnical section of the camcorder is not working properly and u cant align that your own.
thanx
jasdeep
Posted on Jun 30, 2009
  • 6 Answers
SOURCE: My sony dcr-hc28 developed a problem where the
apply a DC voltage of 5v to the tape motor at the bottom of the camcorder. you'll find two little semi-hemispheres on top of motor. trial and error to figure out which is positive.
Posted on Jan 31, 2010
SOURCE: I have a Sony DCR-HC28
toss it on the ground and kick it across the room.....Mine did the same thing yesterday. After I kicked it, wife said "now we have to buy a new one" Problem solved!
Posted on Aug 12, 2010
I have a Sony DCR-HC28 handycam. The cassette door opened and now it will not close. It keeps on flashing an icon that looks like an eject sign and repeatedly says re-connect power source.
Aug 02, 2010 | Sony Video Cameras
Hello my sony handycam dcr-HC23 keeps on giving
search youtube for vids on this Sony camcorder C:32:11 problem
there are several.......
Jul 14, 2010 | Sony DCR-HC62E Mini DV Camcorder
I get a c31:23 error message on sony camcorder dcr-hc28. Any suggestions to fix this?
That code is telling you your heads dirty, no do not buy Shampoo just a tape head cleaner from local camera centre, all will be fine okay?
David
Jun 20, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
DCR HC 23E. Cannot close the cassette. Camera asks
mechanism is faulty.flex cable (FP-031-12) is broken. replace complete mechanism or flex cable (FP-031-12) by any service person
Apr 05, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
SONY HANDYCAM DCR-HC28 CASSETTE WONT CLOSE.
my camcorder need to do re attach the powe source ,how can i fix it
thanks
Feb 09, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
My sony dcr-hc28 developed a problem where the tape will not reinsert and i get a message "re-attach power source". i re-attach, nothing changes. i remove battery, power source, re-attach, nothing...
Dec 17, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
ERROR C:32:11
GO TO REPAIRING INTERNAL PROBLEM
Sep 09, 2009 | Sony Handycam DCR-TRV140E Digital...
Connecting Lyd Model#203 mini-cam to Sony DCR-HC28 Handycam
The HC28 has a/v out only - whereas the HC32 has a/v in/out capability of which only certain models of camcorders have.
Oct 06, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Driver download
pls provide Sony Handycam DCR-HC28 driver file for win xp sp3
May 15, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
My computers do not recognize sony dcr-hc28 camcorder
Hi, I'm from the Philippines. I have the same handycam model. The first time I connected it to my PC (Windows XP) via firewire, nothing happened. It cannot detect my handycam. I returned the firewire card to the shop where I bought it. They tested it and the firewire card is ok but the firewire cable is defective so they replaced it. When I got home, I tested it again but still the handycam cannot be detected by my PC. I went online to find a solution and I came upon a solution that you need to attach/connect your charger to the handycam before you connect your handycam to your PC. It said that the handycam needs a steady supply of power to be able to connect to the PC. It sounded weird but I tried it and BINGO! The handycam got detected. I was able to capture my videos.
I also have a TV Tuner & Capture Card but when I capture videos thru the RF cables, the videos losses quality and videos are blurred. Thats the reason I bought a firewire card.
May 04, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Sony Handycam DCR-HC28 Mini DV Digital Camcorder Logo
170 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
