Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Blinking timer light will not turn off.
Could you please send me the manual to rosiecards@yahoo.com, and tell me how I can mke this stop blinking and turn the tv on. mitsubishi hdtv1080. thank you!!!!! i have a WD52725 and the screen all the sudden went blank and the timer light keeps blinking. i have clicked the reset button in front and have unplugged the tv and same blinking green light ?
happy new year great way to start
  • Anonymous Apr 15, 2009
    blinking green light ... no video and audio... black screen.... how to make it work for movietonight!
  • telcomqueen Apr 21, 2009
    The flashing timer light wont shut off, I cant turn the TV on and have done multiple resets, and unplugged the power supply without resolution. HELP!!
  • 979 Answers
You most likely have a fault in the defelection circuitry that is causing this. A repair is needed, none-the-less....accordianman
Posted on Jan 01, 2009
Send instructions in how to operate a bryant zone plus thermostat
Download the manual at this link... http://www.manualslib.com/manual/22463/Bryant-Zone-Perfect-Plus-A96447.html
Jun 28, 2014 | Heating & Cooling
No picture
Send me a copy of the service manual, and I will tell you what you need to check on this set before you throw it away. Send it to, techman32k@yahoo.com and remind me what set this is for, what website the set is located in.
Jul 27, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Panasonic 47wx42f won't turn on. Power light
check your manual for the trouble shooting. The number and speed of the blinking lights will tell what the issue is. It could be and burned out lamp or the lamp timer may be at it's limit and needs to be reset.
Jan 29, 2010 | Televison & Video
Power light on pc mv1214 laptop blinking but wont on
have you already got a solution for this problem?, please send me a message if you have, kindly send me at this email imalwayzme_md2008@yahoo.com... your response is highly appreciated.thank you
Oct 18, 2009 | Sharp Computers & Internet
Green blinking light
the chassis needs to be rebuilt.check out www.tv-techs.com
Jan 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Pull out the power cord from the outlet for about one minute and then replug it. The blinking will restart for about a minute or less and then the set will turn itself off. You will then be able to turn it back on in the usual way with the remote or power switch.
I believe this is caused by a power surge or a momentary power outage.
SG
Dec 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Honeywell HZ-705.....HELP!!!!
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Aug 17, 2008 | Heating & Cooling
Mitsubishi TV WS-65713
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The green light keeps blinking. thanks
samzlades@yahoo.com
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Red light blinking, how do I determine which cartridge needs replacement?
open lid with power on, carriage should move to left and stop look where it stops on area behind carriage there is a triangle that points to a spot on carriage indicating which ink need attention
Or there is a status monitor that comes with print driver that tells you on computer
Nov 01, 2007 | Epson Stylus C88 InkJet Photo Printer
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
488 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
