Question about Everex StepNote NC1500 Notebook
Everev Stepnote - Turn off Touchpad
I would like to turn the touchpad off. I usually use a mouse and would like to shut this touchpad down....
How do i disable touch pad when mouse is in use
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
Jan 31, 2016 | Toshiba Satellite C655D-S5120 Notebook
My cursor jumps to random places when I am typing
you need to make sure that in the mouse software has the PalmCheck on to make sure that it won't jump when you are typing
Mar 03, 2011 | Dell Latitude E6510 Notebook
My mouse has stoped workin i just turned the lap top of and turned it back on again and it wansnt working the click button does'nt work either.
If you are referring to an actual "regular" mouse, unplug it from the USB and try plugging back in again.
If you are referring to the "TouchPad" type on a laptop, usually there is a tiny button near the touchpad that you may have inadvertently shut off by hitting it. Mine is right at the top part toward the screen, but still part of the touchpad. If you can't find the little button then refer to your manual if you got one to find out where the off button is for your touchpad and turn it back on.
hope this helps, if not I will check further to see what to do!
Feb 27, 2011 | Computers & Internet
How do I turn of the mousepad on my lenovo 3000 N200 laptop? I am using a remote mouse & sometimes the pointer jumps to a different location. Turning off the mousepad may help?
If there isn't a button directly over your touchpad for turning the pad off\on, then there should be a function key for doing this. Typically, you will have to press the Function key, usually located near the space bar, and press one of the "F" keys at the same time. Look for one of the F1 - F12 keys to have a symbol for the touchpad or mouse. That's usually the one that will turn off the touchpad.
Aug 04, 2010 | Lenovo 3000 N200 Notebook
Can't "tap" on my Dell touchpad
I had the same problem after purchasing an HP laptop with a Synaptics TouchPad. After using a wireless mouse for awhile, the TouchPad stopped working. The TouchPad light was white, indicating it was enabled. No TouchPad devices was listed anymore in the Mouse Properties in the Control Panel. I tried reloading the driver but nothing changed.
After shutting down the laptop and removing the battery (according to owner’s manual) it worked again. After turning on the laptop, make sure the TouchPad works. Then go to Control Panel, Mouse, Device Settings tab, and make sure a Synaptics TouchPad is listed in the Devices list and that the Enable button is grayed out.
May 28, 2009 | Dell F3534 Touchpad
My acer aspire touchpad frozes
right click My Computer >> Manage >> Device Manager.
See if the drivers are installed
May 22, 2009 | Acer Aspire One PC Notebook
Quickplay touchpad above keyboard
The following illustration and table describe the computer TouchPad.
(6)
TouchPad on/off button Enables/disables the TouchPad.
Component Description
(1)
TouchPad light Blue: TouchPad is enabled.
Amber: TouchPad is disabled.
(2) TouchPad* Moves the pointer and selects or activates items on the screen.
(3) Left TouchPad button* Functions like the left button on an external mouse.
(4) Right TouchPad button* Functions like the right button on an external mouse.
(5) TouchPad scroll zone* Allows you to scroll up or down.
(6) TouchPad on/off button Enables/disables the TouchPad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 08, 2009 | HP Pavilion dv9000z Notebook
I have toshiba notebook A200.I have been using a USB mouse,and I now can not get the touch pad to operate.Plerase advise me what I can do.I have tried FL F9 to no avail.
If you unplug the mouse and then start up the machine does the touchpad not work at that point?
Some systems have a settings in BIOS that prevent the touchpad from working if a mouse if connected.
Try unplugging, start up and if the touchpad doesn't work, shut down and go into the system settings and turn on the touchpad (if turned off).
Also, make sure the device manager doesn't show any Yellow Exclamation points, meaning a bad or missing driver. To get to Device Mananger, go to control panel, system, hardware, device manager (in Windows XP that is).
Jun 01, 2008 | Toshiba Computers & Internet
Touch pad center click button no longer works
Near your clock, you'll usually find an icon for your touch pad (probably synaptics). Open this & select mouse properties, in there look under Device Settings & try the "Reset Devices" icon.
If that don't work, Click start>control panel (classic view)>mouse.
On the Touchpad tab, make sure the 'tapping' box is checked . Click apply, click ok.
If that doesn't work, click start>run, type devmgmt.msc
and click ok.
Click the plus to expand Mice and Other Pointing Devices.
Right click and uninstall any mouse or touchpad listed.
Reboot.
Let Windows rediscover and reinstall the touchpad drivers.
Good Luck!
Jan 09, 2008 | Acer Aspire 3680 Laptop
Everex StepNote NC1500 Notebook Logo
159 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
