Question about HP Pavilion 761n PC Desktop
Upgrading two USB ports on front panel
I added a Belkin USB 2.0, 5-Port PCI card to my HP761n computer. Naturally the 4 ports on the PCI card all work at the 2.0 std. But the two front USB ports still indicate the older speed of 1.1.
I assume I need to unplug these two front ports from the mboard and plug them into the 5th internal USB plug on the Belkin's PCI card. The problem is the two plugs are not compatible. The plug on the Belkins card is a standard USB plug, and the plug on the front port wires (two)are what I believe to be a 'double row of 5' header pins. I believe they refer to this as a 'Intel Standard USB header Layout'??
1) Is there a simple conversion device that would allow this two plugs to be connected??
2) Or do I need to consider getting a new terminal plug (std USB) added to the wires of the front USB ports?
  • brian eiland Jan 01, 2009
    QUOTE=those pins should connected to ur mother board only...
    QUESTION: But if it were only a single USB port on the front of the computer it could be connected to that 5th "internal port" on the PCI card, right?? So why could.t it be possible to get both USB ports on the front working via that internal port on the PCI card??
    QUOTE=once check ur bios settings..
    QUESTION: Does this have any bearing on my motherboard's inherent (as deliveried) capability of supplying USB1.1 rather than 2.0 ?? That would indicate to me that I might have been able to upgrade my computer to USB2.0 without installing this Belkin card??
    Just beware you are talking to a relatively computer illeriate :)
    New Friend:
  • 59 Answers
Hi..
there is no such converter..
or
use external usb hub..so u can get multiple usb ports that u need...
Posted on Jan 01, 2009
Can a Windows 95 have a usb port installed
Yes.
Load the required driver from Microsoft but it will not be USB 2 only USB 1.
Oct 16, 2010 | Computers & Internet
How do I install 5 Port USB 2.0 Desktop PC PCI
please re post with the manufacturers name of the card. or go to the maufactueres site and download the drivers for it there. foe example if it is a belkin go to:
www.belkin.com
then go to support and then downloads. they will have it.
Jun 25, 2010 | Computers & Internet
Lost install instructions for Hi-speed usb 2.0 5-port PCI card.
The drivers are here. You shouldn't need to do anything to install the card other than plug it into a PCI slot in your computer and install the drivers.
Hope this helps. Thanks for using Fixya!
Feb 19, 2010 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
Does my w3507 have an agp port
No it does not have an agp port. IT has a PCI Express Port for video cards. Its much better and faster.
Details on your machine and what it has can be found at this link. Hope it helps.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2912877&CatId=2643
Nov 10, 2009 | eMachines W3507 PC Desktop
ASUS P4SDX USB Ports not recognized as USB2 HS Ports
The message comes up when a USB 2 device is connected to a slower USB 1 or 1.1 port. It is only to advise you that the devise will operate faster on a USB 2 port. If your computer has only USB 1 or 1.1 ports, you will always see the message. You can buy and install a card with USB 2 ports and install it. It will come with the USB 2 drivers. Install the card and the drivers and then connect your USB 2 device to the new hardware and you should not see the message anymore.
Good luck, And let me know ho it works out for you.
~ Spoem
Mar 30, 2009 | ASUS P4SDX Motherboard
Case front firewire port to motherboard connection???
Yeh dont plug it into a USB header...
yes if you buy a PCI firewire card they will have 1 or 2 headers on the card so you can fit your front Firewire port to it...
[Belkin cards 99% of the time have headers on the card]
Let me know...
Matt
Jan 22, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Can not identify Belkin N1 Wireless USB Adaptor on PC
Hi, A couple of things: 1. Have you tried all the USB ports of your desktop PC (front and back)? 2. What is your desktop PC brand/model or at least the motherboard? and What OS please?; 3. If running Windows in the desktop PC, can you please check in your Device Manager if your USB are 2.0? 4. Are you using a USB hub or directly connected to the PC's USB port? Hope this be of some idea/help. Pls post back with your desktop brand/model/motherboard. Good luck and kind regards.
Sep 16, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin N1 Wireless Adaptor not connecting on PC
what the adviser meant was your pc cannot provide enough power to the usb port to power the unit, assuming you have tried other ports and it still wont work; you will need to either purchase a pci usb 2.0 card adapter or purchase a mains powered usb hub and connect to this instead.
Sep 15, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Computer freeze on saving files to USB 2.0 External Hard Drive (and USB2 flash drive)
Suggest you look at the motherboard book to check if or how many USB connections are in fact USB 2 compatible. Most modern Motherboards only have 2 USB 2.0 Compatible connections, most are 3.0 or 4.0 compatible. Hope this helps, Malcolm Campbell.
Mar 12, 2017 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
HP Pavilion 761n PC Desktop Logo
322 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
