Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Deodorizing the vacuum
I have a Dyson (animal) vac. I has a definate smell - pet odor when I use it- just turn it on. How can I freshen or deododorize it?
First of all Clean out the vacum cleaner . Empty canister and take filter outside and hit on something to get all dust out . Now wash canister and filter with vinegar water and let dry before using vacum again. You might try using carpet fresh for pet odors on carpet and empty and clean canister and filter regularly. I own a cleaning business and this is a hard problem to solve with all vac. cleaners. Good Luck!!
Posted on Jan 01, 2009
Is there a deodorizer for the dyson animal vac, when it's running it smells foul?
I have the Animal CD-07 and what I do is take some Lavender oil and place a few drops of it on the filter. That way at least it smells better. Works for me!
Aug 13, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson Animal vacuum smells horribly of dog. It's worse than my dog has ever smelled - even at his worst. How do I take apart the Animal to clean it properly? Can I use a weak water/Chlorox solution...
hi Donna.
Complete removal of pet hair from the home is a quandary many pet owners face. The Dyson Animal series vacuums use centrifugal force to remove animal hair from carpets, floors, curtains and upholstery. The high-powered vacuum is bagless, allowing you to extract pet hair from surfaces without worrying about running out of vacuum bags. As your Dyson Animal vacuum is exposed to pet hair and dander, a smell can develop. Similar to other small appliances, a vacuum needs periodic cleaning to keep it looking and smelling clean. When you use basic cleaning and deodorizing techniques, you can get the smell out of your Dyson Animal vacuum.
Step 1
Remove the bagless receptacle for pet hair according to the directions provided for your Dyson Animal vacuum. Hold the receptacle upside down inside a trash bag and tap the bottom to remove pet hair and dirt.
Step 2
Mix 1/2 tsp. of dishwashing detergent with 1/2 gallon of warm water in a bucket. Dip a clean cloth into the soap solution and wring it out.
Step 3
Wash the inside and outside of the receptacle with the cloth to remove dirt and dander that cause odor. Rinse the receptacle with a cloth dampened with water. Dry it thoroughly with another cloth.
Step 4
Remove the HEPA filter from your Dyson Animal vacuum. Pick visible clumps of pet hair off the filter and discard them. Flush the filter with cool water to wash out dirt and hair. Rinse the filter until the water runs clean. Gently squeeze the filter and allow it to air-dry for up to 12 hours to ensure it dries completely.
Step 5
Moisten a cloth with undiluted vinegar. Wipe off the exterior of the vacuum with the vinegar. Deodorize the receptacle and interior areas, where the bagless receptacle and filter go, by wiping them with the vinegar-moistened cloth. Dry the vacuum with a clean cloth.
Step 6
Place two drops of vanilla extract on a cotton ball. Drop the cotton ball into the receptacle before securing it to the vacuum to prevent odor from building up. Vanilla extract is an effective natural odor absorber.
hope this helps you out.
Nov 28, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
How can we avoid the odor that we usually have with other vac exhausts? will cleaning the filters as suggested really keep that from happening?
Bagless vacuums have a real problem with bacterial growth. That is what produces the odor you are smelling. Wash the cup in an enzyme and the filters too if they are the washable type. Make sure everything is dry before you reassemble the vac. Then turn on the vac and pull the hose out like you would be using the tools. Holding the hose end that has the suction, spray a small burst of Lysol Spray into the hose opening so the vacuum "sucks" the Lysol through it's interior. This will kill the bacteria in the hose and the plastic housing of your vacuum. Usually 3 bursts works fine. If you spray too much and get your machine "wet" with the lysol you could damage your motor so small bursts are better than a long spraying action
Oct 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson Animal, lost suction and bypass valve seems to be loose
Dear terrygivens, 2-17-2009 4:12am EST (USA)
Most suction problems are caused by a clog from picking up something you probably didn't see or if you have pets an accumulation of pet hairs!
To clear it out take a metal coat hanger and unbend it til it's straight, then bend the end and tape it so when you push it through to unclog your vac it doesn't rip the hose.
Push the coat hanger in from the bottom brush area through the opening where the suction is. Also push it in and out anywhere else you can......You'll probably find something clogged....keep working it til it loosens and intermittently turn on the suction.
If you have a second vac with a hose, use that hose for suction on the clogged vac!
This should do it!
jack
Feb 15, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dog smell after cleaning
This is an inherent problem with bagless vacuums. The filter(s) will absorb odors and odors will get trapped in places that you cannot clean. This is why I always recommend bagged units. They are easier to clean and the odors go out with the bag. About the only thing you can do is put a deodorizer in the machine and keep the filter clean. Be careful not to use petroleum based deodorizers as they can affect the plastic.
Feb 17, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
1,226 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
