Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Light blue shade of hase in middle of the screen with
My tv has a light blue hase in the middle of the screen with little blue dots in the middle of the screen what could it be
  • Scott Frye
    Scott Frye May 11, 2010
    Hi...
    I second that. Most likely the light engine ( NOT cheap)
    I hope that its under warranty
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Proble of light engine, blue LCD and UV filter defective in light engine.
    Sony Qualified Tech will do the job. Check warranty, if valid then call Sony Customer for warranty cover.
  • Sony Master
  • 5,138 Answers
Light Engine FOR SURE Just did one last month retail on part $2,500.00 Call UED I got mine for around $900.00 1-800-648-6657 ask if they have any rebuilt ones cheaper.It was for a 55 inch prices very . I checked on a 42 and with core exchange 400.00
Posted on Jan 01, 2009
Can a blue dot on a tv screen get worse or stay the same.
One little blue dot is not enough to warranty the television. If you read all the documents on the set, it will tell you that some imperfections in the display are allowed. The good news is that it wont get any worse
Feb 23, 2015 | Element Electronics Element 50" Class...
I have small blue dots and a yellow shadow in the middle of my screen
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.
Let me know if you have questions.
Dec 02, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
Have little blue dots in the middle of the screen when TV is on - already changed blub and dots are still there - cause?
The cause is a bad blue TFT panel in the light engine. Unfortunately the only solution is to replace the entire assembly. It is available at http://www.encompass.com I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains how to remove and install a new light engine as well as where to get the parts. If you need more help let me know. Thanks for using FixYa and for the generous rating.
hardrocko
Mar 19, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
It has blue dots in the middle of the screen
This is a defective Light Engine Assembly. The average cost to replace it is around $650.00
Jan 09, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Blue section (corner) and blue dots
This set has no internal manual adjustments for color. The Tracking or B&W balance is accessed via the service menu. I don't suggest you attempt to adjust without instrumentation. the trouble with your set is not an adjustment. Most likely the Optics are at fault. This model has had issues with filters in the optics being destroyed over time by the lamp. The blue haze will get worse and continue to grow over the whole picture. The only option is to remove the Optics (light engine) and sent it out to be rebuilt.
Apr 14, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Kp-51ws510 picture issues
Bob, remove the front speaker panel and you will see a small access panel remove that also and you will see a small block with 6 dials on it. three on top and three on the bottom. Look closely at the dials and you will see focus for 3 of the dials and Screen for the other 3. The dials marked screen control the drive amount for each tube and are laid out like the tubes green dial in the middle and blue dial on the same side as the blue tube. try turning the blue tube down a little. If that deosnt help you will no doubt need a new blue tube, which is a fairly common problem with that model Sony. If you require more assistance please let me know.
Aug 08, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
135 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
