Worked first time straight out of box but after problems connecting a laptop to same network this printer now won't connect.
I hada the same problem. I used the settings on the actual printer rather than through the software to input the information it needed and It works fine now. I was able to set it up on my husbands laptop without any problems, I just added his laptop through installing the software on his laptops as it had picked up the signal and was showing in the Network and sharing centre on Windows Vista premium. Hope this helps. I think you need to take the wire out now and now load it as wireless. You need to use the wire first to connect then take it out to connect to the wirelss network. My router is a Sky router.
Tiptap
I was also having same problem with my epson printer. I called epson tech support at toll free number - 1-800-585-2494 and they have fixed my problem instantly. for more information you can visit: http://epson.techssupport247.com/ . hope this will help you better.
I have an epson sx600fw and a mac - i was printing perfectly using the wifi and now i can't see the printer anymore
I also have an Epson SX600FW and it has full Wifi signal strength as does my Mac too but it only prints now and again. I have to send a print job about 10 times for it to print. Usually works best when I turn off the router, printer and WiFi on the Mac and then reboot. Shouldn't have to do this though, is really annoying. Any ideas?
Tiptap is right. Initial setup should be done with the ethernet (not USB) cable attached. After setup, disconnect the ethernet cable. If you are having problems it's to do with your network, not the printer. I didn't have to touch any of the network settings on the printer, I just installed the software as per instructions.
I have exactly the same problem. It connects perfectly by wire but will not connect by wifi. Has anyone esle had similar problems with the Epson SX600FW printer?
cannot connect at all even pc world could not hep
SET UP AN AD HOCK NETWORK WITH MAIN DESK TOP TO BE ABLE TO USE PRINTER WIRELESS TO LAPTOP IN OTHER ROOM PRINTER SHOWS ON LAPTOP WITH NETWORK ICON IN GREEN BUT WILL NOT PRINT
