SOURCE: Programing codes for a Protron TV
The codes for the 32' Protron are 1004 or 1011. However be aware that this may disable your defaults permanently. When we had the cable installed they changed the codes but on doing so, the TV was useless. On power up the led will go from red to green, then go back to red instead of giving a source option. Customer service is agravating and useless; this is Chinese company that is using the name ProtRon to ride on the better make of Proton. We bought it through ShopNBC, definitely a big mistake since they are of no help either. We have taken the TV to a repair shop; they say its a main board but they are having extreme difficulty getting help from Protron; only delays and excuses. There are more issues riding on all this that has prompted my wife and I to seek a class action.
SOURCE: QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
SOURCE: Remote Sensor on TV Doesn't Work and Can't Manually Adjust Menu
I just realized that there is no usb port on this tv. Called tech support at vizio since I'm still under warranty. They're sending a new remote. I know it's not the remote because neither the verizon nor the vizio remote works, although the vizio remote will intermittently work if I'm one foot away from the sensor on the tv and holding the remote on a downward angle. Tech support says they will send a new remote to rule that out before they send a tech over. I'll check the posts to see if you find a solution when I finally get the tech guy out here. If not, I'll let you know what he does.
Good luck.
SOURCE: Code for cable TV remote - 26" Insignia 720p HDTV
I just bought a 32" Insignia NS-LCD32-09 using the Cox (suddenlink) remote and the code 0463 worked fantastically for me, Thanks!
