Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Wire around the seal of front door nexxt washing machine
I can,t get the wire back on
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch front loader washing machine
Posted on Jul 22, 2013
  • Bosch Master
  • 3,463 Answers
If it is the one on the outside you need , you need to locate it behind the lip of the door seal and stretch it gradually all the way round the seal, it sometimes helps if u can get someone to hold it to stop it from slipping off as u are putting it on.
Plz rate my solution.
thanks.
Posted on Jan 02, 2009
Washer leaks when it isn't packed full of clothes.
check your door seal if leaking in the front if the back its probably one of the water lines leaking
Feb 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
The wire around the rubber seal on my bosch washer
This video will show you how to change a door seal on this Bosch WFMC2100UC washing machine
Jan 01, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Mold and mildew all around the seal.
The only solution here is for you to replace the door seal, and in future, do more high temp washes, as the prob is caused by doing too many low temp washes, ie: 40--50 degree temp washes, this causes build up of bacteria and the like.
Please rate my solution.
Thanks.
Oct 18, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Wire off around door
This video will show you how to change a door seal on this Bosch front loader washing machine and the best way to get wier back on te door.
we have al bosch repairs in our channel
May 13, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
How do you replace the door seal on a Bosch Nexxt front load washer?
Tilt the m/c back and remove the clamp securing the seal to the front of the cabinet, double the seal back inside the washer door opening, and then pull the retaining spring off the inside of the door seal which is fitted in a groove at the back of the seal.
Refit the new seal starting at the topmake sure the seal is fittef the right way up, drainage holes to the bottom.
Work the seal on all the way round the drum, and then roll the spring into the groove at the back of the seal and work it round all the way round the seal, you will find it easier if you have someone to help hold the spring in place..
Refit the seal round the front of the cabinet,and refit clamp at front.
Plz rate this solution.
Thanks.
Dec 19, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer Leaking
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process of how to fit and replace
Sep 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
67 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
