Question about Dell A215 Computer Speakers
Static noise coming out of speakers
I have a loud static noise coming out of my computer speakers. I know its not the speakers themselves. I plugged in head phones and the noise is still there. When I play music the static drowns out the music and the song sounds horrible in the background. What is this? Sound card?
  • chad_houston Jan 01, 2009
    It is a desktop. It only does this every once and a while. Last time it did it , I banged on the side of the tower and it stopped. Doing it again though and banging is not helping. Yeah I know banging is not a technical fix lol but I always try it first!
  • jlvshorses Feb 19, 2009
    I have the same problem but I don't have a laptop. It's a desktop and the static changes when the computer does tasks, etc. The static is very loud and high pitched when it is initially started. This seems to prevent the monitor from capturing a signal and I must manually restart several times. The manual restarts are harming my system as sometimes things get lost or don't load properly. Someone told me to get a big magnet and try to **** out the static? Might that work?
    Guru:
  • Dell Master
  • 829 Answers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Posted on Jan 01, 2009
I found this post looking for an answer - I had tried disconnecting everything possible, closing windows, restarting etc...but hitting my laptop worked!!!
Posted on May 06, 2009
Static on HK395 satalite speakers
It might be beacuse of some sort of wireless interference like a cell phone.
Mar 10, 2014 | Dell HK395 Computer Speakers
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
When I turned on the power for my 'Logitech X-240' speakers, there was a loud static noise coming from the speakers. I unplugged the speakers from the subwoofer, and as I began to plug them back...
clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 31, 2011 | Logitech X-240 Computer Speakers
Poor volume and static
Make sure the audio cable is not damaged, sometimes you can unplug and replace that cable. Also check to see if the cable is firmly plugged into the computer. Then last thing is to check is to plug the speakers into another device (ipod, phone, laptop, another computer) and check to see if you are still getting static, if you are then there is a problem with the speakers themselves and you will need to buy new ones.
Hope this Helps
Mar 08, 2011 | Compaq Audio Players & Recorders
My computer speakers have a staticy/scratchy noise coming from them, and it' loud as heck. My speaker just all of a sudden got really noisy. I can only describe it as a static or a scratchy sound. It gets...
Turn off you computer and pull out your sound card if it is external. Then plug it back in the same hole. It may just be loose. If this does not help try another card. If you have a built in sound card try installing updated drivers for it from the manufacturers web site.
Dec 11, 2010 | Computers & Internet
I've got an HK-595 system (Subwoofer and 2 satelite speakers with controls on one speaker for Center, Bass, Volume, Treble and Surround) for my PC. Everything worked fine for quite a while, but then (it...
I am having the exact same problem with my Harmon kardon PC speakers. It is related directly to the speakers (subwoofer). If you plug head phones into the headphone jack on the satellite speaker you will not hear the noise. I am still searching for a solution, I love these speakers!
Nov 05, 2010 | Harman Kardon HK595 Computer Speakers
Insignia PC speakers - give a weird static feedback noise
I'm going to vote for the haunted option.
Sound like you have some noise on your power lines. This can be caused from many different things. Normaly it is a motor going bad or a compressor starting up. From the AC unit or refrigerator.
See if you can correspond the noise to anything else happening in the house. Fridge starting up, AC or heat cycling on...etc.
It may be that you just have speakers and a cordless phone going bad at the same time.
It might just be Casper the friendly ghost playing tricks... ha!
Jan 23, 2009 | Insignia 2.0 Speaker System (2-Piece)
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Static noise
Check for the Third earth wire of your computer else check for the motherboard taking earth for the cabinet.
Good luck
Oct 09, 2007 | Dell WL6000 Computer Speakers
Speakers do not work
yes thats the fact when you plug a headphone into any speakers the head phone will be the only one to function the speaker stops thta the circuit technically which will break the connection of power to speaker if you plug head phone
Jun 29, 2006 | Logitech X-230 Computer Speakers
Dell A215 Computer Speakers Logo
3,056 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
