Question about Kenmore Oasis HE 27082 Top Load Washer
A necklace has gone and wrapped itself inside the drum
We are trying to take apart the machine. obviously by taking the back off of the machine we are unable to see our problem as it is incased in a white tub and we need to access it from the top. We have taken the two back screws off with the latches. It feels like it would come off but the front is still attached. Does the front just pop off?
There is a cap on the agitator plate. Pop this off to access the retainer bolt for the agitator plate so you may remove it, hope this helps.
Posted on Jan 04, 2009
I think my necklace fell thru the holes of my Kenmore 70 series washing machine. How can I check if it is under the drum.
The link to the video will show how to gain access to the inside of the washing machine. I did not create the video.
Follow the safety guidelines in this video and those that came with your machine. This may well be a two-person project, especially if the machine is installed in tight quarters.
  • Take your time.
  • Be safe.
  • Use the proper tools.
  • Do not get frustrated and break any of the parts, after all, you want the machine to function again after you find your necklace.
Take pictures of screws, brackets, covers, etc. before you remove them to make reassembly easier.
You may be able to see your necklace and remove it without disassembling the washer as fully as described in this video. To be prepared for that have the following on hand:
  1. flashlight
  2. GrabEasy Grabber and Retriever PF0401 The Home Depot
    (I have a similar tool and use it frequently)
Whirlpool Kenmore Top Load Washer Disassembly Washing Machine Repair Help
Dec 16, 2015 | Kenmore Washing Machines
How can I find my necklace in my dryer?
First check the lent catching screen and then the vent and hose and the ground below the vent exit. Completely clean those out. If you don't find the necklace in that process, turn the dryer on to see if it will eject the necklace into the vent hose. If it is trapped behind the drum, you should be able to hear it rattling around. However, dismantling the dryer can be dangerous so you should consider a hiring a dryer repairman to do that if it is necessary.
Jan 13, 2013 | Dryers
I have whirlpool LHW0050PQ4 washer, after connect prower, start light is flash and hear click but no water in and is not working
Hello.
It can be tempting to ignore washing machine noises, especially if the machine is still working. But washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
4 Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer makes a rattling noise when spinning
Hi
If its rattling check the drum for anything caught in it.Washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Loud noise during rinse cycle
Hi
If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. Also check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 03, 2011 | Frigidaire Washing Machines
Making noise when running
Instructions: 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. 2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) 3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. 4)Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. 5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. 6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Feb 09, 2011 | Washing Machines
My daughter's necklace is stuck in the drum of my bosch nexxt 500 washer
the drum may have to be removed and taken apart in order to get the necklace out.or the chain may have to be broken and the rest ran down to the drain pump for removal
May 18, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
When the washer is filling a loud noise is coming from the motor, it sounds like a bearing is going out. It seems to do it mainly when the washer is draining, but it starting to make the noise through the...
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Nov 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
Noisy bearing
  • Step 2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
  • Step 3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
  • Step 4 Clear the water pumpmag-glass_10x10.gif from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
  • Step 5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
  • Step 6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  • i think this will help you
  • Aug 03, 2009 | Washing Machines
    Washing machine has started to make noise. What could be the issue.
    could be coupler or bearings on the bottom of the agitator and tub
    Jul 09, 2009 | Maytag MER5775Q Electric Kitchen Range
    Kenmore Oasis HE 27082 Top Load Washer Logo
    54 people viewed this question
    Sal De
    fordexpert
    Robert Rankin
