Question about GPX D1816 DVD Player
Connecting DVD to cable only TV and Modulator box and Dish Networ
I have a old TV with only a cable hook up. I bought a modulator box and used it which works but I can't get my Dish network to work without unhooking DVD player. I want to hook up the TV, Modulator, and dish without unhooking things each time.
Without knowing the actual ports on each of these devices, all I can suggest is that have you tried connecting your DVD to the Dish box (thru VCR scart connection at the back of the Dish box) and then the Dish box into your modulator (and then modulator into your tv.
I have a similar system set up but we have a Sky Digital box here, no idea if its the same as a Dish box but im assuming so.
Posted on Jan 01, 2009
How to connect to cable box and TV using only coax cables
If I understand you correctly you do not have the RCA inputs on the TV and need to hook up this DVD with a coax cable.
What you will need to get is a RF modulator with both coax and RCA inputs. This will allow you to connect the Cable box up to the modulator with the coax line as normal and then the DVD with the RCA cable to the modulator and then the modulator will connect to the TV with a coax giving you access to both. Here is an example of the type of Modulator you will need.
MODULATOR
Good Luck....
Jan 14, 2010 | Jwin JD-VD502 DVD Player
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Dvd player /vcr dont have rf cable hook up
    you need to go buy what they call a dvd modulator so you can connect using coax cable to the tv as long as the tv is cable ready they cost about $30.00 walmart , bestbuy etc
    May 13, 2009 | Philips Magnavox DVD/VCR Dual Player
    Connect magnavox dvd to ge tv HELP!
    You need to go get an RF modulator. They can be purchased at Radio Shack or a number of other electronic shoppes for a reasonable price.
    The RF modulator connects to the coax cable connector and it has inputs for the RCA connectors.
    Cheers ... Best wishes
    Jan 30, 2009 | Televison & Video
    Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
    What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
    If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
    Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
    Hook up
    Purchased a rf modulator and hooked in to the tuner out to modulator and from modulator to tv that made everything work
    Apr 12, 2008 | Philips Magnavox DVD/VCR Dual Player
    Trying to Install
    Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
    Feb 04, 2008 | Panasonic DVD-RV41 DVD Player
    Zenith xbr716
    ALL cable is digital.
    What type of TV do you have? Does it have any scart conections on it? If not connect the Cable box with a scart lead to your VCR select the AV channel on your VCR, connect your VCR to your TV via the RF connection, (if it has not got one, its not a TV, its a monitor). Tune your TV in to the video channel.
    You do not need an RF modulator for a home TV setup, whoever told you that is a fool.
    Dec 28, 2007 | Zenith XBR716
    Connections
    Hi If I'm understanding what you have written, the new DVD should hook up exactly the same way your old one did. You connect the red and white cable from the "Audio out" connectors on your new DVD to the "Audio In" connectors on the RF modulator, then connect the Svideo out on the DVD to the Svideo connector on the RF modulator. Then put your TV on channel 3 or 4 depending on what the switch on the modulator is set to, and all should work fine. I would advise you hook your old one back up, then if it works, simply unplug the cables from you old DVD and plug them into the proper jacks on the new one. This eliminates bad cables. If you then get sound, but no picture, the DVD may be set to progressive scan (check manual for procedure take it out of that mode),If you get nothing, then I suspect there is a problem with the new DVD player. The TV/VIDEO switch they mention, would be a switch on the TV or TV remote if you had a newer TV with RCA inputs.....You don't, so disregard that, it does not apply to your TV. You would not need the RF modulator if your TV had that switch. Good Luck!...These things can be a pain, I hope this helps!
    Nov 28, 2006 | Daewoo DVG-9200N DVD Player
    GPX D1816 DVD Player Logo
    201 people viewed this question
    Top GPX Televison & Video Experts
    Blake
    sonic boom...
    sonic boom...
    Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
