Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
The canister will not click into place.
There are no visable signs of broken parts ?.
David,
It sounds like the canister is not put together right.. double check that.. Also,
make sure you line up the "red lines" and snap into place.
I had the same problem, easy fix..
Hope this helps
Posted on Jan 01, 2009
Nothing going into dirt canister
Is there suction at the hose? If not it is either blocked or the suction fan is broken. If there is, then there is a blockage in the pickup section, something is lodged across the channel after the brushes and before the place where the hose plugs in.
I think there is a safety switch to prevent it from running with the canister out so hard to check for suction at the top of the motor/suction fan. Make sure nothing is over that part under the canister too! If you can figure out how to bypass the safety switch (if there is one), you should have good suction where the canister sets on top of the motor base.
Oct 06, 2012 | Dirt Devil UD40270RM Quick Power Compact...
Every thing clean & sucking well except wont pickup off floor. brush in good condition &rotating. any answers would help.
This is hard to answer without see it in person. Check and make sure there is no broken pieces on the bottom where you could loose suction. Also make sure you have the machine set correctly for either bare floors or carpet. If it is on set on carpet and yopu are cleaning bare floors you might loose suction there also. Also make sure you check all pathways for the dirt to get to the canister fo any signs of blockage. Are all the filters in place like they should be? Sounds like the suction is getting diverted from the floor somehow, make sure everything is secure and locked in place on the canister. Also check on the top of the handle and make sure the little purple screen is moved back into place covering the top of the handle, you could be sucking more air in thru this inlet and not enough off the floor! This is usually moved out of the way when you connect the hose to the handle for your attatchments. It may still be pulled back and needs to be moved forward into place!
Nov 15, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Belt for Hoover Powermax S3606 Canister Vacuum is Broken
Your belt number will be listed on the data label with the model number. Check your local Hoover / Dirt devil dealer for the part.
Mar 04, 2010 | Hoover S3606 Bagged Canister Vacuum
Rainbow Model e Series will not start. Where is the reset button on this vaccum?
There is no reset button on the canister. It may be a bad power switch, a power cord, or the button that presses in when you put the water basin in place may be bad - or the prong on the water basin that pushes that button in when you place the canister on the basin may be broken off.
May 25, 2009 | Rainbow 75th Anniversary Canister Vacuum
The clip that holds the EL5 powerhead to the wand has broken (again). How does one fix this?
i found this part online- search for part # via an exploded parts diagram of your specific unit (via google)
i ordered 5 of them because it always breaks or pops out.
this is a nice machine with crappy parts.
sorry :(
May 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
4.3 amp Kenmore canister vacuum power switch has failed
You did not give the complete model number, but you can go to sears.com, click on parts and put in you model number. You will get links to click on, click on the cannister one and you get a picture breakdown and a parts list, you can also order after choosing the part you need.
Aug 09, 2008 | Kenmore 22812 Bagged Canister Vacuum
Broken canister latch
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=604237
Posted by nestara on May 17, 2008
The little plastic latch that holds the canister in place (the lower part that is recessed) is broken. I need to find a new part to replace it. I cannot seem to find one so far...most sites just offer replacement bags/filters....etc.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Sorry you are having a problem with the replacement parts for your vacuum but if you contact the Eureka Factory Service line of which I will list below, they will either supply you with the part or give you a contact factory dealer that will get you the part and also you may as for a schematic or and owner’s manual in order to see how to repair the part. If you have further questions, feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 17, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Broken power head belt
Not sure which one you have, need complete model number. You can go tosears.com, click on the parts link, enter you model number, click on the powerehead link. A parts list will come up along with a picture breakdown of it.
Alot of them the part covering the light is just snapped into place, push in on the side andback to release it. Remove the 2 screws, use a flatblade and stick in the slot on each side from the bottom and pry up to release it.
The other type, you tak out the 2 screws from the bottom, then on the back and each side are release tabs that you pry out to release.
May 08, 2008 | Kenmore 23613 Progressive PowerMate Bagged...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
73 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
