AEG Lavamat Problem
Thank you for your help. Your solution makes sense as I had the problem intermittently. Sometimes the wash wouldn't start and the error code cd would appear but I'd shut the door again and it would work. However it doesn't work at all now. I have one quick question. The door light is on green which means that it registers that the door is closed. Could the sensor still be faulty even when the door light is green? I would be very grateful for your answer.
Tahnks again and Happy New Year.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
To your specific question, no. However, on most models, there would be 2 door switches. Might it be then that the other switch (if present) would be causing the failure of operation. There are even versions that has a relay on the doorlock itself. Incidentally, often, there would be a tech sheet at one of the of the panels. The tech sheet would contain error codes and user action possible. In most instances, there would be a wiring diagram that would help you as long as you have access to a continuity tester or a DVM/VOM.
Since AEG/Lavamat models are not a common brand in my country, most that we have worked on are re-branded variations. But the basic operations would still be the same.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Jan 01, 2009
My washing machine stops and shows C9...what's wrong??? (it's an aeg oko lavamat caresse) Who can help me?? cheers Jan
AEG Lavamat 'C9' decodes as 'tacho fault' i.e. something wrong with the motor/speed/sensing. Sorry but that looks like an engineer call is required;-0(
If this has clarified the situation and/or assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 29, 2011 | Washing Machines
How can i solve the error C6 in a AEG Lavamat
c6 is indicating a fault in the water level sensing . either pressure switch defect. leaking pressure tubes or blockage in pressure chamber that the tubes connect to,
May 03, 2010 | AEG Lavamat 88840 Front Load Washer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Aeg lavamat w 1050 electr. rubber problem
dears, thank you for repling of my subject , i solved the problem with replasing other new rubber .
thank you again for your interesting
Mar 23, 2009 | Kenmore 22422 Top Load Washer
Lavamat 86800 stop the washing cycle after few seconds without any error code
Hi - did you ever find a solution to the problem? My 12 year machine now showing the same issue.
Oct 11, 2008 | AEG L86800 Front Load Washer
AEG lavamat 6955 showing F9 on display panel
unplong machine and restart it .eamonn eire thank you
Jan 26, 2008 | AEG Lavamat 88840 Front Load Washer
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
