Question about Desa International GWRP26T Infra-Red Wall Mounted Panel Heater
Problem with pilot shuting after heater thermostat cycles off
The pilot lite goes out after the heater cycles off. could it be thermo coupel or a problem with main thermostatic control
  • 188 Answers
It could be a few things:
1.Not enough fresh air or the unit is too large for the room it is installed.
(Try to open a window)
2. It could be low gas pressure. This can happen it your LP tank is low or something is wrong with the line.
(Call your gas or LP company)
3. ODS Pilot may be clogged.
(Use a vaccum cleaner, pressurized air, or a small, soft bristled brush to clean).
If this does not fix the problem you may need to replace the pilot. You can contact them at 800-446-1446 or on-line at www.masterparts.net. I hope this helps!
Posted on Jul 13, 2009
Raypak problem, Pilot is lit, can jump TH to TH to lite, goes out when jumper is removed.
check how many millivolts the pilot is generating. if pilot stay lit and burners wont fire u have a problem with one of the safties, lose wire connection, tstat control
May 28, 2013 | Raypak Pool & Spa
Wiallwialliams wall heater wont stay on installed new thermo coup aready
Get a AA battery and tape a wire on each end, then attach the wires where the pilot generator wires to, mv/pv and pv usually,if it runs this way the valves good, the pilot generator makes 750mv or 3/4 of 1 volt, by the dissimilar metals in the pilot generators numerous thermocouples, they make 30mv each and are used on water heaters only now.
Dont run it with the battery if you sleep! test only.
Oct 31, 2012 | Williams (5009622) Ceramic Gas Wall...
Larrs lite llg natural gas heater - the only way i can light the pilot is to remove the valve knob and push the valve pin in manually - that lights the pilot everytime but when the pin is released, the...
This is a problem with the thermo-pile. Yoiu need a 750 millivolt general replacement thermopile. You can purchase at your local HV AC supply store. Should cost about $45
Jan 23, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light goes out
if the unit goes thru the cycle of heating the water and when temp is met pilot goes out you need to replace the entire temp control if pilot goes out as soon as you release the pilot button you need to replace the thermo couple little copper wire the goes from regulator to inside burner...check for 800 number on front of w/h for warranty info..as regulator can be expensive
Dec 09, 2010 | Reliance Natural Gas Water Heater Control
I have a rheem fury 50gal gas water heater that will not stay on. I have replaced the thermo couple, it did lite but then went out.
I would like to know how old this heater is. This information can be found on either model or serial numbers.It won't appear obvious but last six numbers will tell you. You have already changed thermo-couple so I would check to see that it's properly centered in pilot flame.When you light it hold pilot button down for two-three mins.while watching thermo-couple.It should be a nice cherry red. If it is and pilot goes out after you release button then you either have another bad thermo-couple or gas valve is bad.If it does not get cherry red at least on tip then you need to reposition thermo-couple and try again. If gas valve is bad and heater is less then six years old valve will be covered under warrenty,however labor won't typically be covered unless you have extened service contract.Hope this helps.Thanks.
Nov 03, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a ventless gas heater. the pilot lights
It just has a little dust in the pilot safety and that makes it think low oxygen levels are present. Ti correct that situation I flush the pilot safety device with rust buster, I relight the heater with pretty good success. I have a page which shows where to clean and has a nice demo which shows exactly how it works HERE
Feb 28, 2010 | Heating & Cooling
My living room gas heater will not stayb lit
Try replacing the thermo coupler.There should be a little bulb shaped part(like a pencil eraser) that the pilot light heats up .The other end screw into the gas valve.If this is going bad or has gone bad the pilot light will not stay lit.Most of these are under$10.Well good luck and try to stay warm.
Feb 02, 2010 | Grilling
Jandy Lite 2 - Pilot goes out when I turn to On
Sounds like you need a new thermo couple. found at most hardware stores
Jun 23, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Propane heater goes out after heat cycle
I've seen excessive draft draw the pilot flame away from the thermo couple when the burners light so when the burners shut down so does the pilot.
Feb 08, 2009 | Coleman Propane Forced Air Heater...
Desa International GWRP26T Infra-Red Wall Mounted Panel Heater Logo
106 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
