Question about HP Pavilion MX70 17" CRT Monitor
Possilbe to reset monitor?
Im just wondering if its possible to reset my hp pavilion mx70 monitor back to its original state. i cant see the colors red, pink, orange etc and i'd like to bo able to!
i've tried fixing its resolution, and resetting the monitor, but they just didn't work! im getting very frustrated!! does anyone know how to fix a hp pavilion mx 70 monitor that doesn't show red, orange, pink, etc???
    Guru:
  • HP Master
  • 829 Answers
This document pertains to MX50, MX70, MX75 and MX90 CRT monitors.
NOTE: To reset the monitor to factory settings:
  1. Turn off the monitor by pressing the POWER button.
  2. Press and hold the plus (+) button and then
  3. Whith the Plus (+) button pressed, press the power button to turn on the monitor.
  4. Release both buttons.
Posted on Jan 01, 2009
How to reset HP monitor p2330h?
It will be slightly different on all monitors, but generally on the menu button on the screen, use the arrow buttons on the screen to navigate, find reset.
Jun 14, 2014 | HP Pavilion MX70 17" CRT Monitor
I have an hp pavilion a720n desktop with an hp pavilion mx70 monitor and windows xp home. There is a problem with the color displayed on the monitor. I see mainly black and white, but blue shows up fine....
First of all you can check the computer by connecting another monitor to it to see if the problem goes away...if so then the problem would be in the monitor. If not , then I would try to change the video grafics card in the computer(assuming you don't have built in video). If you have built in video on the mother board then you will either need to replace the motherboard or disable the onboard video and install a video card
Dec 19, 2010 | HP Pavilion MX70 17" CRT Monitor
HP Pavilion dv7 goes into sleep while im gaming what could the problem be? overheating?
Hi, Click on start, controlpanel, power options, advanced and check your settings there. But depending what support you have inside the computer gaming could be too much.
Feb 06, 2010 | HP Pavilion MX70 17" CRT Monitor
My color monitor (hp pavilion mx70) is having graphics problems
Need to download correct graphics drivers and then you will be able to change the options. If you already have up to date drivers then you need to Right Click on desktop and select properties and then click on the Settings Tab and change it from 16 color to Highest (32 bit). Oh, go to manufacturers web site to download drivers.
Jun 30, 2009 | HP Pavilion MX70 17" CRT Monitor
My Hp mx70 monitor Will rendor the color green as black
Dear Killkerson,
As i understand from the situation, Please do the following:
1. First confirm that the problem is with the monitor. You can do this by trying this monitor on any other CPU. If the monitor behaves Fine, the problem is with the Video Card (Nvidia in your case). If the monitor behaves the same way on other CPU as well, i recommend taking it to nearest service centre. Please Do Not open monitors yourself (Some CRT's may have a possiblity of electrocuting people because they can store a charge upto 25000 Volts in Capacitors). Better get that serviced by authorised people if it doesnt work on any other computer.
2. If the above monitor just works fine on any other machine, probably the problem lies with Video card adjustment.
Please Right click on an empty place on your desktop and click on Nvidia Control Panel. (or you can go to control panel and try to run the same from there).
you will see that Nvidia's video card utility will open. On the left hand side, you will find (depending on the model) 3 basic options.
1. 3D settings
2. Display
3. Video & television
Expand the Display option and select "Adjust desktop color settings" on the extreme right on the top, you will find an option of "Restore Defaults." Click on that and close the utility. Check if that has resolved the problem.
If not, please try resetting all the options back to Default on the Video control Panel one by one.
I am hopeful that it will solve your problem.
Feel free to contact me if it doesn't solve. I will try to help you till it does.
Have a wonderful day ahead.
Regards,
Techno-Geek.
Apr 23, 2009 | HP Pavilion MX70 17" CRT Monitor
Monitor won't come on right away
Sounds like the CRT is starting to go bad cause its taking longer and longer for it to boot up. CRT's aren't available now so a new monitor would be the only option.
Apr 09, 2009 | HP Pavilion MX70 17" CRT Monitor
Monitor is missing pins?
If the monitor is working correctly, there is no problem. Not all 15 pins are used, therefore there is usually two missing.
Jan 24, 2009 | HP Pavilion MX70 17" CRT Monitor
Hp pavillion mx70 stopped showing red, etc
Right-click on any open space on your desktop. Click on properties and the Display properties will come up. Click on settings and make sure the resolution slide is all the way to the right. And Color Quality is set to 32 bits on the small window.
Jan 01, 2009 | HP Pavilion MX70 17" CRT Monitor
I want to know if my monitor is Vista compatable
Yes, the monitor is Vista compatible. A monitor is just a display device, simply showing you what's coming from the computer's video card. That video circuitry is what would need to be compatible with Vista.
If you are upgrading an older computer by installing Vista, you might need to be concerned about video hardware compatibility. If you are upgrading by simply replacing the computer with a new one, it will already be Vista ready. In either case, the monitor will be fine.
Please take a moment to rate this solution if you've found it what you need, and thanks for asking here!
Dec 27, 2008 | HP Pavilion MX70 17" CRT Monitor
Monitor won't work with new computer
The computer in question has two graphics cards in it. A GEForce 8400GS Graphics card and an onboard graphics card. It could be possible you are plugging the monitor cable into the wrong graphics card slot. The onboard graphics card slot may be a different color than the GEForce graphics card slot. Check the back of the computer to see if there is another spot to plug in the monitor.
Jul 13, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion MX70 17" CRT Monitor Logo
688 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
