Question about Coby DVD815 System
Problem with coby dvd-815 surround sound system
Gently used (hardly at all). Now, some discs that have played fine before are either not working at all, or verbal sound not heard. Background sounds coming thru fine and picture fine. Some discs that have played before are not playing at all. Cleaned with a proper clean kit, problem still there. Lost owner's manual during a move. Need HELP!
2 Suggested Answers
SOURCE: my coby dvd 925
Go to setup and change it from 5.1 to 2 channel audio. I have no idea why, but it worked for me. Cobyusa.com/solutions is where I found it at. Good luck.
Posted on Mar 20, 2009
Coby DVD968 surround sound w/TV
you have to check to see if your TV also has "AUDIO OUTPUT" ports, they would be red/white (not next to a yellow - those are inputs", you would hook up red/white from back of the TV to the back of the DVD player where it is labeled "input", you then turn on the dvd player and press the 'source' button to switch it to the right input for your connection. P.S. - it will only do the front two speakers because your tv only outputs 2 channel audio.
May 19, 2013 | Coby DVD968 Theater System
Surround sound for DVDs.
If your DVD disc supports it, you will have to enable surround sound from the DVD, as well as the speakers.
May 10, 2008 | Koss KS3102 System
Tip
Remote Control Problems
hi, BEARHOUSE IS HERE WITH THE Answer i Purchased a Memorex MVD2022 DVD Player at a Goodwill Store For $7.00 Dollars. I Had a Coby Model# 224 with Remote Control My Coby Quit Working the motor Drags. I had Both DVD Players on top of Each Other Tried The Remote For The Coby and The Memorex DVD Player Blinked. So I Cut off The Coby And What Did Find I Found that the Coby Remote Worked on the Memorex The Buttons Are Different But Works Good Enough For Me.
The Setup Button Eject the Disc and the >> fast Forward Button Turns it on and off
and the Program Button works For Sub Title other Buttons have other functions for The Memorex MVD 2022 Only thing You Have to work the sound From Surround System are TV.
on Feb 23, 2008 | Memorex MVD2022 DVD Player
Problem
first you most clean the laser with alcohol and try again or change the region code on your DVD player.......
Jun 13, 2010 | Coby DVD-215 DVD Player
Nexxtech ESDVD100 DVD player gone bad, how to replace?
You can try cleaning it with a dvd disk cleaner first. If that dont work by a cheap dvd player and run it to the inputs on the back of the surround player.
May 24, 2010 | NexxTech ESDVD100 System
Can i connect a coby 5.1 dvd home theater system to a 32 inch vizio and be able to watch tv with the surround sound on. I know the surround sound can play while im watchin a dvd but i would rather just...
you need a logitech sound adapter or game adapter that costs 4-10$ on ebay.
Connect LR channels using an RCA cable and hook up the speakers on the other end of the game adapter
Jan 10, 2010 | Vizio VW32L 32 in. LCD HDTV
No sound through surround
this is because the home theater receives 5.1 channel... change it it will work...
May 17, 2009 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
I can't get my coby DVD 937 to play sound while watching tv. It works fine while playing a DVD or CD????
there should be an input line of just audio cable hookups (one red and one white) that you have to run and an output cable from your tv audio output of just red and white. make sure the tv says output or line out and the surround sound system says input or line in
May 05, 2009 | Coby DVD-937 5.1 Channel DVD...
Coby TR-DVD8500
Sounds like it's a problem with the optical sensor in the disk drive. Try and clean the little sensor with a cloth. If that doesn't work then you may have to send it back to Coby for either a warranty replacement or a repair.
Apr 13, 2009 | Coby TFDVD5000 Portable DVD Player
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
Coby DVD815 System Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
