Question about Hotpoint WD62 Front Load Washer / Dryer
Drum bearings I need to take the drum bearings out do i need a special tool. thanks
    President:
  • 1,462 Answers
Hammer and cold chisel but try to hit the outside of the bearing not the middle otherwise it may disintegrate. you really need a simple bearing press to put new bearings in
Posted on May 07, 2007
How do i fit bearing to the drum ?
As you should know most bearing comes with instruction how to install bearings and some you could find instructions on line .
Most likely you need to use special tools or bearing installation and removal tools .
Most likely you could buy them from appliance parts stores or auto parts and major tool stores or online tool stores stores and as you should know there are many different size and shape of bearing tools.
You have to be sure what kind bearing tools exactly you need
Be sure not to damage the bearing and drum when installing and removing old one and installing the new bearing
Jul 10, 2014 | Hotpoint Aquarius WF210 Front Load Washer
Where to buy the bearing and seal for drum on front loading EWF272EL washing machine
It seems no bearing kit for this model. The drum bearing is hard to replace and seal it properly if you do not have special tool to do it.
Oct 22, 2013 | EuroTech Washing Machines
Drum bearing
look to see if there are any tamper proof fasteners on the machine, if not then as long as you have torx head and allen wenchs with the other basic tools you should be good to go
Jan 31, 2010 | Indesit WA 125 Front Load Washer
Mod WFW 8400tw00 the bearing on the drum is out and the drum
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Outer-tub-item-number-AP3773839.aspx
Bearing NOTsold separately...
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bearings that support the drum on my front load washer are making
It is replaced from the rear of the drum, beneath the pulley.
You need a bearing puller tool and some common sense.
Take photos as you work, that aids reassembly.
Jan 06, 2018 | Frigidaire GLTF2940ES Front Load Washer
Drum bearings
Removal of the front seal (just the side right next to the door needs to be removed) is a spring loaded wire. There is a special tool for it, but it can be done without the special tool. Other than that, mostly phillips head screws and a few metric bolts. The suspension shock absorbers have a tab you need to depress to push them out.
Aug 19, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Hotpoint wm80 bearing replacement!!
The drum will have to be removed.
Bearing replacement on ANY Hoover can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Hoover washers require at least 2 specialized tools for removing certain components of the machine.
Jun 26, 2008 | Hotpoint Washing Machines
Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
Mar 20, 2008 | Maytag Neptune Washer
Bearings-maytag washer
And you probably need special pullers/press tools too. Look up a web site see in there is a manual on offer
May 08, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Hotpoint WD62 Front Load Washer / Dryer Logo
75 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
