Question about GE Spacemaker JVM1640SJ Microwave Oven
Not heating food
My mirowave stopped heating things up
  • nd1l Feb 20, 2009
    The same problem occurred to us yesterday, accompanied by a loud humming noise. Help! Our model number is JVM 132J001. It's rather old now, around 18 years, but if it's a simple fix we'd prefer to fix it over replacing it.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    What is the model number?
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • 6,993 Answers
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Testing a diode
NOTE: Before you test your diode, make sure your microwave is unplugged, and that you discharge the microwave's capacitor.
Whether it is shorted or open, a defective diode will most likely show some sign of defect. Defective diodes will usually emit an electrical burning smell, signifying its defectiveness. Also, it may have split in two, or it may exhibit a burned crack, or possibly even a blistered spot.
A shorted diode is indicated by a loud humming noise from the high voltage transformer, and no heat produced when a cook cycle is initiated. Whereas little or no heat produced in your microwave, with an absence of a humming noise is indicative of an open diode. In either case, the diode has to be replaced.
With your microwave unplugged, and your capacitor discharged, use extreme caution to remove the lead that leads to the capacitor. You can leave the ground connection attached. The side of the diode that goes to the ground is usually marked with a dot, stripe, or arrow. Set your ohmmeter to R x 10,000 or higher. Touch the positive meter probe to the anode and the negative meter probe to the cathode to measure the resistance across the diode terminals. Remember that the cathode is on the side that goes to the ground, which is often marked by a dot, stripe, or an arrow.
A normal diode, that is a non-defective diode, will read anywhere from 50,000 to 200,000 ohms. Differences in microwave make and model account for this large range in resistance readings.
Reverse the meter probes and measure resistance while touching the positive probe to the cathode and the negative probe to the anode. Reversing the probes like this should result in a reading of infinity. Unless a bleeder resistor is present. The presence of a bleeder resistor would produce a reading of the value of the resistor.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
A defective magnetron is the third possible cause of why your microwave is not heating. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
If you cannot perform the above task yourself, ask a family or friend that has the ability to assist you or have a certified and experienced appliance repair technician examine and replace your magnetron. This task is much too dangerous for the average layman to perform on his own.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
I hope the above is helpful.
Posted on Jan 05, 2012
  • GE Master
  • 19,396 Answers
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
2 Suggested Answers
  • 472 Answers
SOURCE: mirowave does not heat food
a common problem with this model is the magnetron goes is located behind the control panel and if changed requires disassemble of the cabinet...the cost of the magnetron is around 100.00 give or take a few dollars. depending on age may be a wise investment to purchase a new could also be the capacitor or diode but if all the timer and lights are working just no heat it is common for the magnetron on this model...hope this helps good luck
Posted on Jan 06, 2011
Why mirowave je2160f01 doesnt heat the food
This is usually caused from a bad magnetron. The door interlock switches couls be bad or the high voltage diode could be bad.
Aug 24, 2014 | GE SpaceMaker Microwave Ovens
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
The vent/fan goes on every time we heat food up. how do we stop the fan from going while heating up food?
You cannot do that, it will overheat the unit, that fan does two things, it keeps everything cooler, and "Stirs" up the Microwave "Field". So it is essential for safe and efficient use.
Apr 10, 2010 | Whirlpool MH1150XMQ Microwave Oven
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
Odd buzzing after timer stopped, food was still being heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Aug 20, 2009 | Whirlpool MH1150XM Convection/Microwave...
MY microwave just stopped heating things
therrmal resistor bad . Mine quite working and I found one of two resistors bad. Seemes to be a common problem.
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating food
I have exactly the same problem - strange and annoying! Did you manage to fix it?
Nov 15, 2008 | Sanyo Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
288 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
