Looking for headphone jack on citizen c27401
Can't believe a tv. this new does not have a headphone jack
ThaMp3Doctor
  • 8596 Answers
SOURCE: head phone jack only plays right side/brad new headphones
Call Philips, get replaced - this is a common problem across all mp3 manufacturers. You can look at the YouTube video on repairing mp3 player headphone jacks, but i doubt it will work without causing more problems with your mp3 player.
Posted on Aug 26, 2008
SOURCE: wire has been cut
My wire was cut, and I made it worse trying to fix it....with several failed attempts... was becoming despondent, but gave it one last try, and was successful. First, each little tiny wire has two internal wires, one green (ground) and one gold (hot). At first, the green one looked like some fiber or filler and I cut it, connected the gold wires and nothing happened. On further inspection, with magnifying loopes, I determined the green fiber was in fact green wire. There was also a lot of clear fiber, which is insulation? filler?... I don't know, but I cut it out, leaving only the wires. From the internet, I determined that the wires had a thin layer of plastic on them for insulation, which I burned off lightly with a lighter, connected the green together, soldered it, wrapped in electrical tape, then connected the gold together, soldered it, and taped again....and to my suprise it worked. I used twist ties, and epoxy to strenthen the area and was done, my headphones are working again.
Posted on May 16, 2009
  • 1138 Answers
SOURCE: Do I have any options to get 'audio out' instead of h/p jack?
Try the Audio 1 rear. With the headphones plugged in on some T.V.s the headphone jack unfortunately disconnects the audio from the other outputs. Try looking in the documentation to see if you can change this in the T.V.s menu as some allow you to use both for hearing impaired people. Hope this helps.,
Posted on Jul 10, 2009
  • 44 Answers
SOURCE: want a TV wireless headphone with no headphone jack or audio out
You may have to connect the headset through a VCR or DVD player that does have the output connections.
Posted on Sep 05, 2009
  • 8457 Answers
SOURCE: i need a replacement remote for a citezen tv
Try website 1-800-Remotes Factory original.Get the original or very close to it.
Posted on Dec 07, 2009
We are trying to hook our TV up to our computer to use it as a monitor. What cords do we need to do this besides the normal monitor cord?
if you want audio as well, it will depend on what kind of audio connection your tv has next to the VGA (computer monitor) connection. If it looks like the normal RCA audio, (red and white plugs) you will need to get a male headphone jack (to plug into your computer headphone or speaker out jack) to stereo RCA cable so you would have a headphone jack on one side of the cable and a red and white plug on the other side. Now if your TV just has what look like a headphone jack next to the VGA (computer monitor plug) you will need to buy a male to male stereo headphone jack cable. for both of these, just make sure the cable you get it long enough, or buy an extension.
Mar 21, 2011 | Sansui HDLCD1908 19 in. LCD TV
Is there any way i can put the PS3 and the Hitachi tv throught the cinema system at the same time?
Possibly. I believe the HTC550 only has one audio input so you'll have to work around this. Check and see if you Hitachi TV has a headphone jack. If it does, patch the PS3 audio through the TV. Connect the TV to the HTC550 through the headphone jack using a 3.5mm to RCA cable pictured in the link.
http://www.daydeal.com/files/images3/blk_rca_cable.jpg
Mar 01, 2011 | Samsung HTC550 Theater System
My 26 inch Panasonic Viera TV has what looks like a headphone jack on the side of it but when I plug headphones in the sound still comes through the TV speakers. How do I get the headphones to work?
Check you USER MANUAL to make sure it is actually a headphone OUTPUT jack and not a digital INPUT jack.
If your tv does not have a headphone output jack you can always get an adapter that plugs into the red and white AUDIO OUT jacks in the back.
If you want to turn off your tv's speakers, go to the MENU.
Then go to AUDIO then select SPEAKERS OFF.
Good luck and please post back with how you make out.
Jan 24, 2011 | Panasonic Televison & Video
Where to hook up headphone jacks to allow TV speakers to continue working while using headphones I.E. I have jacks on front of TV but they do not give me out put sound. which ones should I use on back of...
Unless you have an external headphone amplifier, you need to use the headphone jack socket, if there is one. Some newer TV's allow for separate headphone volume and speaker volume control.
Have a look in your user manual.
Jan 08, 2011 | Panasonic CT-36D20 36" TV
I have new RCA model VHP141 Headphones but will not work with my new Vizio TV. Where do I plug them in the TV?
Visio might not have a headphone jacks at all! Look around your set and, probably you won't find jack marked as headphone. You might need to use wireless headphones, what have an rca plugs and connect them to audio monitor out on your tv set.
Alex's TV Service,
Philadelphia, PA 215-806-5980.
Jan 21, 2010 | Vizio VO47L 47 in. LCD TV
How do i set up the Technika TA-709 Wireless Headphones to my tv. Have lost the manual and am not getting any sound only static on all 3 channel selections.
You should have all the necessary cables to do this with the package you bought, the wire which has a headphone style plug on each end should be plugged into the headphone jack on your tv.
If they dont work then there are two further things that could be at fault:
A: The headphone audio volume controls and the actual speaker volume controls on tvs are totally different and if the actual headphone volume is turned down then you will get an interference type noise thru your headphones as no sound is being detected by the reciever and therefore they go into kind of a standby mode. !!!!!!!!!!Try looking in your TV settings menu to make sure your headphone volume is turned up!!!!
B: being an owner of a pair of these headphones I know how audio the cable can easily turn faulty from prolonged use us. The wires can easily break inside but look fine from the outside so get a new one. Headphone jack to Headphone jack cable.
I use these along with my xbox 360 wireless earpiece (fits nicely under the headphones) and I think they're far superior to the Turtle beach headphones +++ My setup is 100% wireless which also makes it better than any turtle beach setup on the market.
Jan 07, 2010 | Audio Players & Recorders
Sylvania TV Headphone Jack Problem (Specifically for a Model TVK199, but I suspect the answer might be fairly generic): The headphone jack on this TV is totally messed up. I'd like to replace it with...
If the audio jack [headphone] has two black bands then it is probably stereo. The first reason you tv phone jack is messed up is because you have an internal ground problem. You may have to resolder this...hope the board is not cracked. I would not advise you to jury rig an outside connection. To do so, you may short the audio chip and that is another problem...like no audio at all. Find someone who knows something about tv repair.
Jan 07, 2010 | Televison & Video
I need a replacement remote for a citezen tv
Dec 07, 2009 | Televison & Video
Have new lcd hdtv. Have old headphones can they
Yes. 2 possibilities:
1 - the new tv has a headphone jack - just plug them in.
2 - no headphone jack - buy a RCA to phone jack adaptor, plug it in the audio line out RCA connectors, plug the headphones into it and mute the tv.
Dec 06, 2009 | Televison & Video
Jul 09, 2009 | Sennheiser RS 120 Consumer Headphones
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
