Kitchenaid top loading quiet scrub washing machine wont drain water out. Need to know how to change the belt. Thank you.
  • 15,935 Answers
It appears your belt has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Kitchenaid quiet care washing machine
not enough information. there may be a loose or broken drum spring, or the belt may be loose and or worn. If its a two speed one of the gears may be worn.
Dec 31, 2011 | KitchenAid Washing Machines
Hello, I love my Ktchen Aid washer and have had it for over 17 years! It is a 3 speed, quiet scrub, extra capacity/heavy duty. The water fills the tub, but does not shut off and over runs onto the...
All you need to do, is see if you can find a Pressure Switch available at a Spares Depot. This is the problem with your Washing Machine. I do not know if you will still be able to get one though. The pressure switch notifies the Timer/Module when there is sufficient water in the Tub to commence washing.
Hope this helps.
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | KitchenAid Washing Machines
Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
Oct 01, 2009 | KitchenAid Washing Machines
Have a admiral washing machine sounds like something is grinding inside while washing and spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 08, 2009 | Admiral AW22 Top Load Washer
KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
no, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Jan 31, 2009 | Washing Machines
CANT DRAIN OR SPIN WATER OUT OF MY WASHER
Set it toward the end of any cycle - it will sense the water level and pump it out before moving on.
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Burned belt?
Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check Sears.com for parts.. good luck...
Jan 23, 2009 | Maytag SAV5710 Top Load Washer
Kitchenaid top load washer
Have a look underneath and see if the drive belt has fallen off. If it has, check this isn't because the pulleys have failed (look for spoke failure near the hub on big pulleys), then buy a new belt. Putting the old belt back on might keep you going for a while in the interim. A.
Apr 11, 2007 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
624 people viewed this question
Top Washing Machines Experts
