Question about Canon PowerShot S500 IXUS 500 Digital Camera
Memory card error
Gentleman, When I press the power button on my camera (Canon PowerShot S500)I get an error message which says: Memory card error. Is this camera faulty or this is a setting problem. Please help me because the camera doesn't take photos any more. Kmawon
  • mehim1 Jun 15, 2008
    When i try to take a picture it keeps saying Card Locked; When it's not locked.
    What do i do?
  • Anonymous Apr 04, 2009
    "If the message "Card Locked" comes up, it means that the memory card'swrite/protect tab is set to "Write Protect". Simply slide the tabupwards to fix."
    I have the same problem. the card is not locked the camera just thinks it is. Other cards work fine, the card is just busted (it won't work on the computer reader either).
    Other cards (the one that came with the camera) still work.
If the message "Card Locked" comes up, it means that the memory card's write/protect tab is set to "Write Protect". Simply slide the tab upwards to fix.
Posted on Oct 03, 2008
I had the same problem on my IXUS 500. I bought a new card because my first thought was that the card was faulty, but that didn't solve the problem. I tried to clean the CF card slot but that didn't help. My last resort was to open up the camera and try to find the culprit. I blew away all the dust which has accumulated over time and touched as many parts as possible to fix any defective contacts. After reassembling everything it worked again, funny.
Posted on Jul 27, 2007
    Novelist:
  • 107 Answers
Either the camera or the card is faulty. There is not a setting which will cause this problem. Try a different memory card, if the problem persists you will need to get the camera repaired.
Posted on Jun 16, 2007
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
I bought two new 8GB SDHC memory cards for my canon ixus500. the old memory card is 1GB ad still works but i wanted more memory cards. neither of the two new cards work. they both say memory card error AND...
If your camera is the type that uses SD cards, then your problem is that the camera was developed in 2004 before SDHC cards were invented. Your camera cannot use them.
Sep 15, 2011 | Canon PowerShot S500 IXUS 500 Digital...
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Memory card is defective error message
Format the memory card on the same camera it is not a battery problem &also reset your camera
Sep 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
SD message error
go into the settings and "format" the sd card, that should solve your problem
kind regards and please don't forget to rate us
Nov 30, 2008 | Canon PowerShot S3 IS Digital Camera
Memory card error message
try to reformat that card via a card reader/writer.. then reformat it using the camera thru the menus.
Nov 29, 2008 | Canon PowerShot A710 IS Digital Camera
Memory card error
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Sep 24, 2007 | Canon PowerShot A300 Digital Camera
Canon PowerShot S500 IXUS 500 Digital Camera Logo
301 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
